i went cruising yesturday and day, just wanted to see what was out and about. Didnt see many skylines, but a **** load of silvias and rex's. and theres some blue r33 with front mount up near calboture. seen it off a main road(today).
Pretty sure I saw yours as I cruised by the beach today? The missus actually spotted it which was strange, and I thought that paint job looks familiar?
Actually saw a strange blue R33 yesterday, looked like a 400R kit in Caloundra.
Was in Toowoomba (buying a model R34 GTR of all things) and a white 33 drove past the shop in Newtown shopping centre. Made me feel like I wasn't so far out of the country (of course then I went to the speedway and realised just where I was - in falcadore land).
I saw old mate 'unwritten law' about 2 thursdays back now. We pulled over had a chat. I felt it worth it, as he was the only person all night who knew the car really wasnt a french spec subi liberty.
Ive got a 1977 2door skyline....black....low...17x7 avanti's...ull know it if u see it....ive had it for 3 or so yrs now and ive never seen anothe of the same model done up...oh yeah..and its a v8
hey shane u saw my mates r33,Nismo blue its an awsome looking car.He lives at bundamba i recon its the best skyline i have ever seen.Its 1997 fmic and has full hks adjustable suspension .The car is hot makes mine look like a piece of crap
Only saw it for a split second, but it looked very, very tidy indeed!
Where have you been??
A few weekends ago I saw two chicks driving your car, then I finally saw it back at the house! Have you been away overseas for work again?
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
