  • Replies 266
Posted Images
The only thing That would come ANYWHERE NEAR the VR is a Z-tune..
Even then, it would still get is arse handed to it..
or.. would it?
Yes the GTR has titanium this.. bollocks that.. electronic jizz control..
But the Z-tune is still pretty hardcore!..
I mean Nimso poured 5mm of Carbon fiber on the floor plan to stiffen it it..
it uses a the GT500 race engine..
Carbon fiber pannels all round..
10.04 or something like that quarter mile..
Same power.. not sure about torque..
I think the Z-tune is ligher..
The gear changes wont be as quick in the Z-tune as in the GTR.. but.. could a Z-tune make up for this?
hmm.. discuss.. im curious..
Edited by GTS4WD
I am almost sure, I think perhaps if the work to upgrade the engine RB26DETT much better than the engine VR38DETT! !
Because LINE ENGINE IS BETTER FROM V ENGINE !!!!!!!!!
In what way?? Have you seen someone modify the VR38 yet??
And what makes you say an inline motor is better than a V engine??
A 'V' engine is much stronger and stiffer than an inline engine...
Can you back up your comments with facts???
It be appreciated muchly from you.... :thumbsup:
It be appreciated muchly from you.... :yes:
The unfortunately reality is that the inline 6 has probably had its day. The packaging benefits of the V6 makes them a better proposition for the run of the mill car companies - particularly those running transverse installations. Even in longitudinal ones the gains are there in making the car easier to engineer for crash worthiness.
But to defend the old inline six (Which I have a soft spot for) they have the following advantages over their bent up brethren:
* Inherent first and second order balance - the V6's either run funny vee angles or need an extra balance shaft.
* Easier packaging when you turbo charge the motor.
* More room on the axhaust side which allows better cooling for the turbo chargers etc.
* Cheaper head castings as you only need two cam shafts & on head.
* They sound much nicer.
how easy would it be to take out the TT setup and throw in a, lets say T51R SPL onto an engine like that (VR)? Maybe compare it to a 300zx engine...I have never had experience with that...is there enough space...how does it all compare to throwing a t51r on a 26 ?
It be appreciated muchly from you.... :(
I have no experience with the engine VR38DETT to you that expectation proved largely true! !
Despite the dramatic difference in STROKER! !
But in terms of the experience of the RB20DET and RB25DET and RB26DETT is better in all respects use or promotion or maintenance or endurance is much better too! ! !
There is no engine V6 6 Slander advantage proved successful only relatively Tourqu be a little better and I say this advantage! ! !
But respects mentioned above inline much better health and days will prove myself! ! Despite the size difference stroker !!!!!!!
NOTE: inline engine only for the 6 slander !! V ENGINE GOOD ON THE V8 ONLY !! OR MORE!!!
Thanks ALL .[/b][/size] :yes:
Edited by bkc
or.. would it?
But the Z-tune is still pretty hardcore!.. I mean Nimso poured 5mm of Carbon fiber on the floor plan to stiffen it it.. it uses a the 500 race engine.. Carbon fiber pannels all round.. 10.04 or something like that quarter mile..
Same power.. not sure about torque.. I think the Z-tune is ligher..
What race engine are you referring to?
If it's the GT500 from SuperGT, then your probably wrong, cause they have been using a V engine in these for many years in the 350Z and a few seasons in the R34's before that.
If it's the GT500 engine from way back when the R34's first came out( In JGTC), then that's a pretty old engine, and I'd still take the VR over it any day.
or.. would it?
the z-tune costs a lot more and will be a collectors item. The R35 will be mass produced. If I was to chose b/w to two, Id go the z-tune.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
