  • 2 months later...
F-----n hot !
Their we go people photos of the first V36 370GT that is in Australia, no it wasn't me who took the photos I have no idea who did.
Don't bother asking me who owns either as it makes no relevance in the scheme of things.
the guys at img motors in sydney told me they should have a manual version in the country for emissions testing as early as november, if they go ahead with that does that mean the manuals will be open slather for importing/compliancing?
Edited by Yo-Yo
how much does a 370gt manual cost?(drive away price)gosh it looks awesome..
I was quoted roughly 48K for a 4.5 grade auction car with 5K on the clock (2007 model, tiptronic) driveaway. That was when the Yen was 80 to our dollar.
As soon as the Yen gets back up into the 90s I am importing one for sure!
+1 . its at 66.72 now and getting worse.
I priced a dash panel for a honda yesterday at 33.600 and that before freight and taxes came out to $502 ex tokyo.
everyone whos pulling stuff out of japan on a regular basis is feeling the pinch.
  • 3 weeks later...
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
