hey guys i am putting a high mount gt35r turbo on my stagea and am having troubles with manifolds not fitting . i now have a 6boost manifold and it fits the engine but the turbo hits on the rocker cover badly . also there is no room for a dump pipe to fit between the manifold and fire wall.
i am running out of ideas this is the second manifold i have bought as the first was my own fault and bought off e bay . has any one else come accross this problem before .please help . manny thanks in advance bernard .
https://www.sau.com.au/forums/topic/193610-rb25t-high-mount-manifold-troubles/
I have a 6boost RB25 mani and ive dummied it up with a GT35 and everything sat very nicely.
Im not aware of any differences between the stagea 25 and the R33 one so il be interested to see this
Post up some pics.
thats funny it looks dodgy as...cough ebay?... gotta ask what size rear housing have you got on the turbo? Im sure with the "genuine" 6boost one, kyle should be able to help you out atleast... if you talk to him and explain whats happening
i have noy got pics of the 6boost one yet as my camera been playing up i bought the 6boost one second hand it has no markings on it but the guy has told me that is what it was .i was in desperate need so i bought it . where could i get a new 6boost one from.
Why not look at going custom? At least you know it will fit comfy and work then... Assuming nothing else fits. But if you keep buying and selling manifolds that dont fit, your going to do your dough.
just do the dodgey, take it down to an exhaust shop and get them to refit the flange on the manifold so the turbo can fit on. probly the cheap and easy way out i think
Kyle spends a lot of time on the collector, filing, smoothing etc, it might be tricky getting a XYZ exhaust shop to modify it. I would 100% call Kyle and talk about your options.
hey guys i scrappedthat manifold and bought a xforce one every thing bolts up fine now wish i could find the guy that sold me that so called second hand 6boost one on boost cruisin and i would shove it up his arse. as every one on here says 6boost are neat this one is not that neat so i am thinking i got had . and he sold me some cheap shit one does the 6boost one have any markings on it to identify it . well if any one needs scrap stainless now i your man ha ha i have 3 good rb25 flanges now as i am going to scrap the rest of the manifold s or if any one wants one to modify will gladly send at your cost. cheers thanks for your help guys and girlys.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
