u could still prob push the frame faster than his commo.
leave an empty letter envelope with a message back on it :laughing-smiley-014:
my traditional game plan for dealing with these kind of bogans is, let em talk all the sh*t they like but if they touch the car its a swift kick up the ass
https://www.sau.com.au/forums/topic/193922-some-greenhorn/#findComment-3478773
GTR's only need to come out of the gaurage when it is required to prove a point. (On the track)
I never park my GTR in plan view on the street, I look for obsecure parking areas in the dark so it doesn't stand out like dogs balls. :(
BTW I have had my car badged in my driveway behind a gate, so I think you came out of it pretty well.
https://www.sau.com.au/forums/topic/193922-some-greenhorn/#findComment-3479808
