haha - the lighter the car the less brakes you need right???
just down shift and let teh engine do teh slowing right!!!!
seriously brake upgrading is the best thing anybody can do to a car....
Smaller brakes = less weight
Less weight = Smaller brakes..
:P thats my theory..
I was lucky enough to already have 5 stud and turbo brakes cos it was a Rb20DET GTS4.. then again.. I did give up a turbo for an NA..
*^$%#@ govenrmnet! :D
brakes,,,, the best thing to do to a car?!!!?!!!?!!
You clearly havent done track work.. or twistie work..
Edited by GTS4WD
you obviously have never tried to pull up really quickly trying to avoid an accident.....
increasing the braking affect (by either better pads/rotors, or bigger brakes full stop) is to increase the brake threshold - the point were you can brake just b4 the tyres lock up
cars are manufactured to fall inside a certain range (i think its got something to do with GVM, stopping distance and engine power)
often a manufacturer will give a car brakes sufficient enough to fall just inside that range - meaning lower cost and less r&d
increase engine power in a car and you need bigger brakes to fall in the range
increase GVM and you need bigger brakes to fall in the range
keep engine power and GVM the same and increase brake size and you are well in the range - and can stop quicker and safer
and in the fact of track work or twisty sections - brakes are used a lot more, they heat up and increase in heat=less braking ability
sometimes a manufacturers brake specs are sufficient to warrant a better pad/rotor combo when power increases
sometimes it requires a whole new brake package
Im weighing up the cost of turbocharging my excel - something i could do for 4g's, 500$ of which would go to slotted rotors, new pads, and possibly converting my rear drums to discs...
/end spiel.... :yes:
Heard about dropping 4g63's in excels?.. This possible?
Had a pub talk with some bloke.. said it costed him 4K all up..
possible?
mines an X3 excel
the X2's were mitsu engined anyway so a 4g63 drop wasnt that hard at all...
in the X3's requires custom driveshafts = big money
can do a 1.8 or 2 litre hyundai lantra engine swap and then turbo, but requires a bit of piss farting around (and the standard gearbox HAS to be used, and the extra torque from the 2 litre kills em really easy)
hey eug, im being lazy atm cause im between job's what still needs to be written up, i duno much bout the rb30 build up's but most other stuff i should be able to find some links floating around for. when i was reading i wasn't to sure how much you wanted covered.
Though i'd add a link to a short write up i did about a year and a bit ago before i'd started actually modifying everything, i'd re-word, evaluate it a lot now but it a good basic write up on what's out there.
http://www.skylinesaustralia.com/forums/N-...want+more+power
same here jarrod, i'm at uni right through the summer holidays.
where was that thread??? i've been here since 2004 and never came across that, sorry for doubling - i'll try to merge the two together when i can. cheers for that
i dont expect these (this) thread to happen over night, it's something we can do and progressively build on it.
Usually stock brakes with good pads are MORE than enough, for one pull up to avoid an accident, and bigger better brakes arent going to stop you any quicker (infact later, more rolling weight!) yes they are heaps better for track/twisties, as the brakes are constantly in use and get hot etc.
personally, I'm happy with my standard sized brakes, with a really good pad, and DBA4000 (slotted & cross drilled) with braided brake lines. Stops damn quick, plenty of bite, very responsive.
So it really depends on what you want your brakes for, but more often than not, you way better off spending your money on tyres, because thats whats connecting you to the ground.
bigger brakes dont hurt, but you dont NEED them, depends on your driving style, imo - im not driving any faster, its for road ffs, only acceleration, which last time i checked you didnt brake during... Ill go bigger eventually, but its not a high priority as really all its going to do is hurt performance everywhere but constant cornering.
also to missr34 - a bosch 040 wont give you any more power, unless your starving your engine of fuel atm. I noticed when i put a bosch 023 in my car, the fpr held its pressure constant when revving (before i revved it and it halved) making it slightly more respnosive, and also stopped a light ping when shifting straight back into high revs WOT. and on newer car like yours, i wouldnt worry until your making a fair bit more power.
some stock brakes can be good but my last car was a subaru rx it had disks at the front and drums at the rear and they were the worst brakes ever even with good pads. i just had them machined and all fixed up and they still made a grinding sound after 10 mins of driving,, it sounded like it had no brake pads but they did. and when i had a few people in the car braking was a bitch it wouldn't pull up quick enough. but driving in the wet was great it stuck to the road like glue. anyway cars these days come with good brakes as standard.
hey eug, i think it was only around for a week before it got pushed over the page, but in that time you made a couple of comments, it was a while ago now so yeh prob wouldnt remember it. i just remembered writing it up and then when i saw this thred thought i might link into it.
hi guys im new to this so help me out if im doing something wrong, i have a quick question about pod filters. If i was to put two pod filters on a N/A skyline r33 would it be any better than having one and will it make a louder sound? This will be in a box and cold air would be coming from the pipe connected to the front bar.
hey that topic was covered in the forced induction section bout 2 weeks ago if you do a search in there you'll find a big disscussion but the end conclusion is no putting on 2 pod filters is pointless as your intake can only flow as much as your intake pipe. The only way to get anything out of it in an na format (or would work on twin turbos) would be running 2 pod's into 2 separate intake pipes and then threw 2 throttle bodys into the plenum chamber, this has been done on an r31 with rb30de. would sound mad as complete twin intakes
hy guys, yes noobs would read this ... i did......and much info was gained .......thanks.....
anyone able to put up info on using rb26 throttle bodies and adapter plate on a 25? thats my next plan after exhaust mods and coils..
Edited by Hesh
anyone thought about or have purchased a itb kit off tweakit performance?
they look pretty good but they're nearly 2K + you need aftermarket ECU + tune.
gonna cost nearly 4K all up.
anyone considered this option?..
hehe
i remmeber seeing a youtube clip of a rb20de r32 skyline (a chick drives it) and it had ITB and it sounded so angry!!
i just had a look at the ones on tweekit, they are universal and need to modify and weld on the throttle bodies, this would be quite expensive with an rb to get much of a gain out of them as you would need to weld on an extra bend on the runners to get enough room to then weld on the throttles. this would drastically reduce flow comparied to the gtr set up and would end up costing quite a lot more cash installing them i wouldnt expect any change from a grand if not 2 so then it ends up 3k plus 1500 for a microtech or some other ecu which uses map sensors insted of a/f sensor, then a tune on anything like that needs a lot of work cause the base maps are for a turbo so prob $800 for a tune more for a good tune. then you need ram filers wich adds anotherbit on top
So your 4k ends up being more like $5200 min and it still wouldnt flow as well as the 26 manifold.
the 26 manifolds go for around 1k if you look hard enough and it wouldnt cost more than 2-400 to get an adaptor plate made up then run individul trumpets a microtech and a tune, prob done for 3k bang that would sound tought as f**k and imadigne the response, and hey whilst your at it why not get them ported and polished for increaced flow add another 400 for that and your still in cheaper than the universal ones.
Its well worth looking into but its a big expencive mod which i could probably safely say none of us have actually tried so the preformance gains would be speculation, another thought could be running twin tb's which has been done before, get your standard manifold modifyed to run 2 stock or a little smaller sized throttle bodies and twin induction tubes with twin pods, would be a big improvment from stock for a more reasnable cost.
You have to think of it this way the best way to get preformance out of an na is to increase the flow of everything reduce all intake lengths, reduce as many bends as possible, get the coldest air possible in, if your running itb's with turmpets buy something like a wrx style bonnet scoup and channel the air over the trumpets so it sucks straight cold air.
Increase the intake sucking with cam overlap ect, increace compression for bigger bang, match the exhaust flow for your engine, get someone to do some figures on what sizes will give you the best backpressure for the best exhaust flow then get it custom made. Smothen and increase everything you car, increase engine compacity, use an rb26 crank and rods to give that extra .1 litres of air.
Reduce any moveing or rotational weight, lighter pistons, lightweight pullies, carbon fibre tailshaft, lighter flywheel but not too much to affect drivability. Lightweight wheels
Remember 1kg of rotational weight is like the same as i think 5-10 kgs of still weight.
Then look into best gear and diff ratios for your prefered motorsport, give the car a diet, what you dont need get rid off
hey guys,
so who here has actualy got sum decent power from a n/a rb20/25/30 ?
after you get a zorst and pod u'd be spending more money then the turbo version is worth just to get the same power.
Edited by Dan_J
hey guys,
But the toruqe, responce and power band simply shits all over a turbo..
So your not going to be able to go quite as fast (top straight line speed).. but F*CK your gonna get there quick!
And even spritired twitie driving.. a decent NA would still leave a turbo for dead.. (given the same suspention, brake and weight)
hey Cris,
but how much effort wud it take 2 get a n/a there
and you can pretty much do the same thing to a turbo so u got n/a torque/response and turbo squirt :D
yes i do agree but thats a v8 or pretty decent v6
anything special been done 2 a n/a rb20 these days?
  • 3 weeks later...
Fuel Pump - Bosch 044 - <www.bosch.com> <$350> Big increase in power..
look im gonna have to burst the bubble here on the whole "big increase in power" via the fuel pump thing, unless you have put BIGGER fuel injectors in aswell.......you WILL NOT get a "big increase in power" because its the injectors that regulate the fuel going in not the pump!!!!!!!!!!!!!!!!
so whoever told you that you would get a big increase in power by just doing the fuel pump is full of shite.
my 2 cents. its been bugging me.
i have done the injestors in my car and i will be getting a Walbro fuel pump soon to put in the car. will post results up when i have done it all.
actually if you want to get into specifics, a fuel reg, regulates the fuel pressure cara ;)
you will see added benefits of a fuel pump if your old one is dying/isn't pumping enough fuel.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
