Hi All,
Just had my highflow r34 turbo blow up and dont want another one so im in the market for a new turbo setup. I've looked at peoples results with the 2530 but want something with more punch and top end.
My car is primarily used for drifting and I already have all the supporting mods.
Who has TD06 kits on their rb20s and which types?
is the 20g kit too laggy? Worth the price tag? Any other turbo suggestions?
Thanks Guys,
Stuart
https://www.sau.com.au/forums/topic/194267-td06-kits-on-rb20/
L2-20G is the go on rb20 for drift and time attack, be aware we have sold around 6 kits over the last 3months so expect to see a fair few on the circuit next year :D
i will post up some dyno graphs for you.
L2-20G is the go on rb20 for drift, be aware we have sold around 6 kits over the last 3months so expect to see a fair ew on the circuit next year :O
As Trent said look at the L2-20G Stu, you wont regret it, only have to look through the Top RB20 thread and see peeps like Troy and Adam and the results.
My car will be running soon so your welcome to drive that to gauge the amount of lag with a similar set up that you would be looking at :D
WIll a TD06-25g be good for an RB25?
Looking at around 300rwkw or would it be best to go the TD07?
td07 is a old T78.... to big, you will see high 400's with a T78. Td06-25g will make 300 depending on housing size. Have a look in the exhaust housing inlet for a number there will be a number between 8-16... this is the exh size in cm2. personally i would use a T67 10cm as i get 280rwkw out of the 8cm T67 on a Rb25 and it makes .7bar as early as 3000rpm!!!! fkn responsive with strong top end.
L2-20G is the go on rb20 for drift and time attack, be aware we have sold around 6 kits over the last 3months so expect to see a fair few on the circuit next year :O
Thanks for that Trent, some graphs would be good! what is rrp on the L2?
I'm not running aftermarket cams or cam gears at this stage...and was told the TD06S-20 might be more suited? thoughts?
Thanks Ben, give me a shout when you've got it on the road!
I may look for something else then.
Im after 260 - 280rwkw with this round of mods but end goal is 340 - 360rwkw
I dont want to upgrade turbo again with the next round of mods
Do a search for Bu5ter. He used to run a TD06SH-25G for 330rwkws odd. Made very strong power and car ran 11s.
As for the 20G and RB20. Can someone explain to me the difference with the L2S? My thoughts are the 20G is just about right for the RB20, just bolt it all up and go.
If its true that there are going to be a few more at the tracks next year then i may again get motivated. Its no fun when there isnt anyone out there to play with, and i cant get within cooee of the GTR guys :D
^^ yeah the TD06SH-25g is differrent than the TD06-25g but, the SH will go 10's on slicks (MSA/CREATD 5spd) and 11's on radials as youve posted here is a kit CREATD used on thier workshop car.. just shy of 300rwkw at 1.0bar from memory
http://www.creatdmotorsports.com.au/galler...hp?g2_itemId=34
this is two totally different behaving turbos a 360rwkw rb20 is going to be useless to drift as its going to be laggy as all shite and run big boost, 260-280rwkw is easy with a L2 but 300rwkw is a pipe dream. T67 will get 340rwkw but need boost and rpm to do it, all enemys of dorri.
you need to decide drift or dyno queen as the two NEVER work together. regardless of turbo brand or people promise.
ok back to my poor little rb20 snotter now :D I want to see peoples results
LOL...if you do a search there are a few around. I only say that as ppl are probably sick to death of me posting my dyno sheet :O
Completely Std RB20, cam gears, Power Fc and GTR injectors with Z32 AFM annd complete Greddy TD06-20G setup using an 8cm rear housing. I previously made 234rwkws with this setup. Having another look at the tune netted me the extra 26rwkws, just by removing what i guess was soem of the fat from the tune. Thats not to say the tune is now a grenade, as i have done soem track days and a 3 day motorskhana/track event in it where the car had to endure me anda co-driver....so the tune is still very reliable
That curve is really quite good! I thought it would be way more laggy! I would have the exact same mods minus cam gears as well. If I start a 2 minute noodle diet right now I could probably afford one for christmas. :D
URAS :D
doh :P rb20 thread with a rb25 infiltrator... f**ked with my head.
T67 10cm or 12cm td06-25g still wont cut it 300rwkw ish maxed, if it is actually a sh-25g 330rwkw is ok.
Below is a R32 RB20 dyno graph. 1.2bar on std rb20 231 corrected rwkw (engine kw is the scale on the graph with more boost) pay no attention to the shape as their scales make it look laggy when actually its really not (the L2 and 06S are very much the same only the L2 is more effecient at higher boost up top.... less roll off). i have also attached a dyno graph of the TD06s-20g on a RB20 you can see it mirrors roys setup only as it runs less boost it only makes 248.8kw
another option is a HKS 2835 56t with 0.61 housing, this works extremely well and i have used these in SR and RB config. (james vahoumis bought my SR HKS 2835 kit and used it in his championship winning s14.5) both Bai and the other D1 drivers prefferred the L2 (like myself) over it though. i also spent alot of time in james cefiro with the HKS 2535 and it was killer street/hills drift but is just too small for serious track drift, 2530's just too damn small.
Tazz - there is a massive thread on it all.
Results, turbos and all the bells and whistles from various users.
If you dont read this thread:
http://www.skylinesaustralia.com/forums/To...60r-t58229.html
Your doing yourself great harm :P
Thanks for the info guys, much appreciated....
I've been fed a few more options from people...so who has used the 3071R on a 20? It looks like a cheaper option...but would it be too laggy even with the smaller exhaust housing? or worth spending the extra money for the L2 kit and be done with it?
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
