Hi All,
Just had my highflow r34 turbo blow up and dont want another one so im in the market for a new turbo setup. I've looked at peoples results with the 2530 but want something with more punch and top end.
My car is primarily used for drifting and I already have all the supporting mods.
Who has TD06 kits on their rb20s and which types?
is the 20g kit too laggy? Worth the price tag? Any other turbo suggestions?
Thanks Guys,
Stuart
https://www.sau.com.au/forums/topic/194267-td06-kits-on-rb20/
L2-20G is the go on rb20 for drift and time attack, be aware we have sold around 6 kits over the last 3months so expect to see a fair few on the circuit next year :D
i will post up some dyno graphs for you.
L2-20G is the go on rb20 for drift, be aware we have sold around 6 kits over the last 3months so expect to see a fair ew on the circuit next year :O
As Trent said look at the L2-20G Stu, you wont regret it, only have to look through the Top RB20 thread and see peeps like Troy and Adam and the results.
My car will be running soon so your welcome to drive that to gauge the amount of lag with a similar set up that you would be looking at :D
WIll a TD06-25g be good for an RB25?
Looking at around 300rwkw or would it be best to go the TD07?
td07 is a old T78.... to big, you will see high 400's with a T78. Td06-25g will make 300 depending on housing size. Have a look in the exhaust housing inlet for a number there will be a number between 8-16... this is the exh size in cm2. personally i would use a T67 10cm as i get 280rwkw out of the 8cm T67 on a Rb25 and it makes .7bar as early as 3000rpm!!!! fkn responsive with strong top end.
L2-20G is the go on rb20 for drift and time attack, be aware we have sold around 6 kits over the last 3months so expect to see a fair few on the circuit next year :O
Thanks for that Trent, some graphs would be good! what is rrp on the L2?
I'm not running aftermarket cams or cam gears at this stage...and was told the TD06S-20 might be more suited? thoughts?
Thanks Ben, give me a shout when you've got it on the road!
I may look for something else then.
Im after 260 - 280rwkw with this round of mods but end goal is 340 - 360rwkw
I dont want to upgrade turbo again with the next round of mods
Do a search for Bu5ter. He used to run a TD06SH-25G for 330rwkws odd. Made very strong power and car ran 11s.
As for the 20G and RB20. Can someone explain to me the difference with the L2S? My thoughts are the 20G is just about right for the RB20, just bolt it all up and go.
If its true that there are going to be a few more at the tracks next year then i may again get motivated. Its no fun when there isnt anyone out there to play with, and i cant get within cooee of the GTR guys :D
^^ yeah the TD06SH-25g is differrent than the TD06-25g but, the SH will go 10's on slicks (MSA/CREATD 5spd) and 11's on radials as youve posted here is a kit CREATD used on thier workshop car.. just shy of 300rwkw at 1.0bar from memory
http://www.creatdmotorsports.com.au/galler...hp?g2_itemId=34
this is two totally different behaving turbos a 360rwkw rb20 is going to be useless to drift as its going to be laggy as all shite and run big boost, 260-280rwkw is easy with a L2 but 300rwkw is a pipe dream. T67 will get 340rwkw but need boost and rpm to do it, all enemys of dorri.
you need to decide drift or dyno queen as the two NEVER work together. regardless of turbo brand or people promise.
ok back to my poor little rb20 snotter now :D I want to see peoples results
LOL...if you do a search there are a few around. I only say that as ppl are probably sick to death of me posting my dyno sheet :O
Completely Std RB20, cam gears, Power Fc and GTR injectors with Z32 AFM annd complete Greddy TD06-20G setup using an 8cm rear housing. I previously made 234rwkws with this setup. Having another look at the tune netted me the extra 26rwkws, just by removing what i guess was soem of the fat from the tune. Thats not to say the tune is now a grenade, as i have done soem track days and a 3 day motorskhana/track event in it where the car had to endure me anda co-driver....so the tune is still very reliable
That curve is really quite good! I thought it would be way more laggy! I would have the exact same mods minus cam gears as well. If I start a 2 minute noodle diet right now I could probably afford one for christmas. :D
URAS :D
doh :P rb20 thread with a rb25 infiltrator... f**ked with my head.
T67 10cm or 12cm td06-25g still wont cut it 300rwkw ish maxed, if it is actually a sh-25g 330rwkw is ok.
Below is a R32 RB20 dyno graph. 1.2bar on std rb20 231 corrected rwkw (engine kw is the scale on the graph with more boost) pay no attention to the shape as their scales make it look laggy when actually its really not (the L2 and 06S are very much the same only the L2 is more effecient at higher boost up top.... less roll off). i have also attached a dyno graph of the TD06s-20g on a RB20 you can see it mirrors roys setup only as it runs less boost it only makes 248.8kw
another option is a HKS 2835 56t with 0.61 housing, this works extremely well and i have used these in SR and RB config. (james vahoumis bought my SR HKS 2835 kit and used it in his championship winning s14.5) both Bai and the other D1 drivers prefferred the L2 (like myself) over it though. i also spent alot of time in james cefiro with the HKS 2535 and it was killer street/hills drift but is just too small for serious track drift, 2530's just too damn small.
Tazz - there is a massive thread on it all.
Results, turbos and all the bells and whistles from various users.
If you dont read this thread:
http://www.skylinesaustralia.com/forums/To...60r-t58229.html
Your doing yourself great harm :P
Thanks for the info guys, much appreciated....
I've been fed a few more options from people...so who has used the 3071R on a 20? It looks like a cheaper option...but would it be too laggy even with the smaller exhaust housing? or worth spending the extra money for the L2 kit and be done with it?
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
