  • Replies 44
Kkr's aren't shit ..
however the kkr430 would have been the better option... unless you want to use it for just drags etc. it's not going to get great response with a stock engine,
John Cane runs (drifter) runs a kkr430 on his Rb25det in his laurel and it goes awesome!
Read specs here > otomoto
I beg to differ.
This guy is making 219rwkw using 19psi and only making full boost at 4500rpm: That is complete SHIT!!
A turbo that only makes 220rwkw should be on full song by 3300rpm. That power is equal to a hi-flowed rb25 turbo at 15psi and look how responsive those are; WITH A STD MOTOR. Not to mention the extra boost required with the KKR shit, is putting more stress on the rest of the motor and creating more heat.
I have previously heard these KKR turbos were laggy, for the power they produce; this has just settled the debate. At the end of the day they are another cheap, China shit turbo that are inefficient and can't make the power with acceptable response.
HKS :D
KKR :(
looks like its hks time lol
when i drove his car with the 2530 it felt like a stock turbo but had alot more mid range/low down torque felt nice, he was only running stock injectors still so car was not really making much more power then mine but felt nice
looks like ill go with the hks item:D
is mid 12s @ 115mph possible with the 2530 turbo?
12s are possible on a stock turbo :D
only making around 295rwhp
yes its laggy bout 4500rpm full boost
the car with 2530 on it i took it for a drive last nite, very good low down torque and mid range wheel spins coming on in 2nd but yeah
i dunno wot to do lol
help me!!! some ppl say 2530 2 small for rb25? im only really after 300rwhp would 2530 get me there easy enough?
what are your other mods, other people in the rb25 turbo dyno thread are making 260rwkw. what are you maxing out?
car come over with 200,000kms phil told me that 6 months after i bought it lol
yes u mite get 12s at 106mph with stock turbo but i want big mph not shit mph lol there is a difference
2 weeks ago i ran a 13.5@102mph in a complete stock r33 on 10psi:)
but it never felt fast cause mph was shit house.
basically the dyno i had my car tuned on made X amount of power
a mate had his car dynoed on same dyno and made 203rwkw or something like that
he went and got a power run on milanco dyno which is a brissy tuner and made 240rwkw or there bouts.. so that mite be my 260rwkw who knows... remember its only tunning tool
Edited by l0WRB
RB30 it and keep the kkr :D
Even with an rb30, the turbo (kkr) is still shit. You'll make more power, better response, and use less psi; if you use a Garrett/HKS/Trust/Apexi/etc turbo.
I am currently building an rb30det and am using a Garrett GT30R (500hp). I am expecting this combo to be more responsive than a rb25 hi-flow, on a rb25; yet make 300-330 rwkw :(.
f**k the rb30 lol
my car is budget and it does 500kms a week its my daily so yeah
well i would be happy with 112mph and 12.5-12.8s and 2sec 60ft's lol
better then my 13.3s and 2.4 60fts
mid 12's at 115mph?
I have an old timeslip at home from WSID, running my hks 2530 on 100% stock motor, no special suspension just re55's, if i recall correctly i ran 12.5 @115mph, with a 1.9sec 60ft! i will try and dig up the slip later to confirm.
If i remember, peak power at the time was just under 218rwkw. Its not the peak that you feel with the 2530, its the punch it gives you mid range, which is fun and makes for great overtaking :(
I enjoyed the 2530 every moment i had it, but the 2835pro i have on it now, :D -but then if its a budget consideration forget it..
Reading this thread the answer is very clear. Whats the point of a daily driver that hits f*kk boost by 4500? Especially if its only making small kw's go for the response :dry:
you still have not mentioned what other mods you have, if you are still running standard injectors, afm and fuel pump then that will be a problem, also do you have a boost controller, wouldnt be hard to set up an avcr or something with lots of settings wrong.
LINK ECU, MAP sensor
700cc injectors
3" dump/exhaust/gutted cat
button clutch
gktech cooler kit
lol at 700cc injectors for 210 rwkw.
but dont stress my last MPH was 116 for a low 13...hahah more to t a good time than a lot of power... I would go the HKS...get some good response and have a nice fast street car.
As mentioned , the figures you quoted are way crap.
I had a 2530 setup on mine, making 225rwkw at 19psi. Best with this setup was a 12.55@113mph. Was a nice easy street setup.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
