^^^ your dreaming kid... "with great power... comes no economy" lol
indeed it was on standard boost, i have the readouts somewhere here!
ive never boosted that car man, never felt the need to
now with the gtr i dont think im ever going to lol
Werd to that grasshopper, as Confucius say "With great power comes great fuel consumption"....or as I say "Power=Fuel" :w00t:
how much does a tune cost at dr drift? its in dandeong yea? looking to get more power / economy out of mine.. i get srsly shit all in my n/a.
everyone seems to recommend dr drift i think i'll be going there :w00t:
He is in Brooklyn, just passed the city on the other side of the Westgate.
Edited by abu
just a little update seemed everyone has bigger stock power figers then me :)
so i had a look around my engine and found a disconected vacum hose from the boost solinode that goes into the cooler pipe.
seems to drive better and have more power lol
Would like to see what mine makes just out of curiosity.
GTST with exhaust and boost tap to make it run bout 9 pound.
BTW, I have no idea of the difference between pound, psi, bar, etc. And am not sure that im using the correct term. I think the car runs 7 pound/psi/whatever as stock and now its on 9.
But im guessing around the 150 mark atw considering no front mount at all.
$120 mate he charged me for a full diognostic it sure was interesting :D
Whats involved in a full diagnostic? I have had my R33 for 4 weeks now and want someone to go over it with a fine toothed comb, then dyno it.
i went in today for a diagnostic coz my car always misfires. he suggested spark problem so i'll have to get onto that. while i was there my stock r33 made 140.1kw while stuttering lol. he said it wasn't a power run though or something like that. dunno wat that means? anyway attached a pic i took of the screen
140 will make a few more when you sort the sparking issue...
fark my lemon i cant belive i forgot to hook up the vacum hose to the cooler from the boost solinoid its beeen off since i thought a fixed the leak and ran it on the dyno with it off too, :P
it seems to have more power and spool faster then i heard another hiss like a blow off valve while on boost farken old hoses.
ill have to go though every last hoes now......................
it seems like i get the hoses under normal boost pressure and the air finds a new weak spot in the system to escape.
when i bought this thing i tramped down some road and it sucked me on the seat and felt bloody awsome seemed to just keep pulling i loved it........
so i know what it can do arrrrrhhhhh :P
sometimes some 'stock' cars can seem to make more power than other 'stock' cars due to a leaning out fuel pump. I know cos this was the case with mine... Dealer just told me it was a 'freak' and that some just made more power - all it was doing was running lean..........
...looking to get more power / economy out of mine.. i get srsly shit all in my n/a.
I've seen so many people go and put extractors on, get their engines tuned up, do custom air intakes and exhaust systems, etc all in the name of getting 'better economy'...
This *might* work *if* you drove using the same amount of power as before, but with less fuel being consumed... but from experience if you have more power, you tend to use it... so worse economy!
i do suburban driving and drive about 30 mins to work and back and im lucky to get 200 k's from my tank, yeah i put my foot down a bit but not all the time it should be better economy then this..
i thought a dyno tune could possibly fix this problem..?
Edited by 4Door_33GTS
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
