by hiding the ebc soleniod in the glovebox for stealth is it bad because of boost response cause the hose is too long?
where are some good ideas to hide it. and if anyones got pics would be much appreciated.
im puting my stock airbox back on with a panel filter also..
https://www.sau.com.au/forums/topic/195187-places-to-hide-your-ebc-solenoid/
Side of the air box?
I have mine in plain view of the cops, right under the airbox with perspex cover.. they love it. to busy checkin out how cool the box looks. just say its not connected if they ask. or you dont know what it is.
You can also mount it in the stock solenoid position under the suspension/roll bar hole
i wouldnt have it in the glove box, like you said the line would be too long. You want the shortest possible line going from the soleniod to the wastegate actuator for best boost control and to help spiking.
If your putting the stock box back in that gives you a few spots to hide it next to. Why do you want to hide it?
i do believe he would want to hide it because anything that is able to adjust booost pressure whether it be electronic type of just a bleed valve type is classed as illegal which is a crock of shizenhousen but owell thats how they roll.... o i know this bcuz ive been done for it b4 ive got a greddy profec b dual stage they dont like it.......
i don't really think you will have much trouble unless you make the vac lines excessively long, glovebox through fire wall is not all that far away.
easy to try however, just throw it under the hood for testing but make the vac lines heaps long, if it works, then move the solenoid to the glovebox, if it doesn't work as good as expected you will have to keep it under the bonnet, but atleast you didn't waste your time running all the lines through the firewall just to test it.
just tell the cops, its the carbon canister purge solenoid and tell them your external gate is an EGR valve. (they wouldn't know what that shit was more then likely anyway) :P
the solenoid needs to be rubber mounted in a place with ventilation. put is on the airbox side somwhere up front. and that way all you need to do is run hoses from the actuator and from the boost source to the solenoid. and put the plug from the ebc controller to the solenoid up to it.
if you are running the ebc controller itself youd want it to be in the cabin. so assuming you are going to run it in the glovebox. run a tee from a vacume line that runs from the inlet plenum. so u can get it as close as u can to where you want it, so the hose run stays as short as possible, before it actually needs to be tee'd.
Nah, some people are just paranoid.
lol thats cos you live in toowoomba :P Come down and spend some time in Melbourne. There are alot of cops here that know alot about modifying cars and they know all the easy things to get you for.
P.S. I grew up in Toowoomba :P
oh and on the topic of the solenoid :P If you are putting the stock box back in try putting it between the box and the guard or the box and the headlights. Makes it easy to jam a bit of plastic or rubber sheet in there with it too just so it can't be seen :P
my blitz one is all black and i mounted it where the stock solenoid was. the TMU officer had a good look at it last week with this flash light and said nothing of it. maybe frabricate a black box to cover. i dont think its a good idea to run the hoses through the fire wall, expecially through the gromet as it'll restrict the hoses.
im going to get rid of it anyway anr un my car standard for atleast 6 months. sellin it cheap for 200 if anyones interested. its a gizzmo one.
but when im ready il try and get a black discreet one and replace it where the stock one goes. i think its a wise decesion there
thanks matey
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
