Huh??? I dunno if i get this one. You want to drive round with no rocker covers on and let all the oil spray all over the place. Is this correct.
Or are you talking bout the coil pack cover in the middle.
Sorry maybe i read this post wrong.
Edited by jrocket
As redevil said above many other cars have exposed coilpacks, and I have been driving round for a couple of years now without it on and my car also passed roadworthy without it so I would highly doubt it could be doubed as illegal.
I'm driving mine around without the cover on ATM cos noone can see it and I'm too lazy to put it back (have to pull the intake pipe off).
Legal? NFI, ring the RTA, they are the only ones who can give a definite answer.
Seriously, the cops keep trying to defect people on silly things, which makes everyone ask questions like the one asked at the top of this thread.
Why would it be illegal is the question to ask yourself. Have a look at the relevant law concerning vehicle standards. I see no mention in there of a requirement of a coilpack cover.
"Why would it be illegal is the question to ask yourself. Have a look at the relevant law concerning vehicle standards. I see no mention in there of a requirement of a coilpack cover."
Why would it be illegal? Cause like you said cops defect people on stupid things. Cause most cops are assholes. Thats why it would be illegal?
The cops do not make the law. The law is made by parliament. The cops enforce the law.
What I was saying is that as far as i'm aware, there is no law on coilpack covers. So If I wanted to remove mine, I would happily do it (but I don't want to).
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
