i was looking for something different to do instead of LED tail lights and found these two pics in my travels.
anyone else like these for something different?
made by Tomei i have a feeling they'd be rare as, perhaps they could be replicated
i want some !
https://www.sau.com.au/forums/topic/195886-r32-owners-sick-of-led-tail-lights/
im not really a fan of them-my 2c
and yeh not a fan of the led lights, look cheap i dunno mayby its just me lol there are some on the 34 that look pretty cool tho, kind of like crystal lights, not typical led style
i've got a set of those, not made by tomei though... still haven't decided to put em on though.
you could very easily make them out of the bottom of glass jars :)
get some r33 tailights, they're the best
and you know it :action-smiley-069:
Yes, R33 lights are the best, BUt in the 4 door variety.....very nice indeed. Maybe try fitting them to your 32, that would look mad!!
Crap sorry, flood control locked me out for a second and i thought my post didnt go though, sorry!!
EMZ
Edited by EMZ R33
whats wrong with led's?
they go well with the ganadors and soon to be clear headlight covers..........................
I have the same lights on mine, I love them.
Havn't had any bad feedback on them in real life yet.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
