I've only had the car a few weeks but something i have noticed is that if i keep the revs low and use even close to full throttle and change up gears without reving high i hear a popping sound from the exhaust which im assuming is a flame out as the tip is black afterwards. My question is, is this normal for a mostly stock GT-T? I just have a cat-back exhaust/pod filter/plumb back bov. Im assuming that r34's are tuned rich from the factory and this is simply a tune issue of too much fuel in and not enough burnt in the combustion chamber?
Has anyone else noticed the same sort of thing? Im sure its no big deal but just thought i'd ask.
Yup thats right.. Car is probably running a bit rich!!
That poping noise is normal for our imports.
Unless it full backfires and is fully hecticly loud popping noise then you gotta start worrying..
Yeah i sorta figured it was running rich, im used to cars throwing flames out the exhaust being the owner of a modified rx7 :P
The skyline is only a fairly quiet pop so nothing major. I guess its time to start planning some mods to be ready for a computer and a tune...
just throwing a tagger on here mate.
i can adjust my fuel pressure so i can adjust the backfire.
atm i just have a slight pop/barble on deceleration.
but when really rich it BANGS!!
how bad is it seriously.
Yeah it could be running rich. You could also try resetting the ECU, see if that changes anything (disconnect battery, press brake to drain remaining electricity in system, reconnect battery).
It's nothing too serious if it's only the occasional pop. When you start getting major hesitation and backfiring around the 4000-5000rpm mark you need to start replacing stuff, usually the fault comes down to spark plugs need replacing or re-gapping, coil packs, o2 sensor, fuel filter, fuel pump.. the list goes on - common problem with lots of common causes. Your occasional pop could be early warning signs of the above. Only time will tell.
Its not loud or bad, its barely noticable really, im just used to listening for stuff like this. It doesnt do it on deceleration either, well at least i havent noticed it do it. Only when shifting up with low revs after having some load. And its not a loud bang, just a light pop. And there's no hesitation at all, it pulls quite smoothly.
The motor seems in pretty good condition too, just had all the belts replaced from 100k service, and new sparks plugs (mayb i need to gap them correctly?), oil, etc.
Edited by Scottydoo
Sounds similar to an extremely common problem. It's doing it as you first accelerate, you go through a zone where it's stuttering or popping and not building boost well then it's back to normal until you slow down again?
Running slightly higher than stock boost?
It probably is running a bit rich, would also explain the blackened tip, but it shouldn't - depending where you intend to take the car I'd be thinking about a A/F addon or better yet an ECU that can manage A/F ratios and get sorted out properly on a dyno.
my car pops when i just let the accelerator go when im goin down a hill should i be worried ill replace my plugs just incase
No, every single car will do it.
It's just slightly unburnt fuel in the chamber exiting and igniting in the exhaust.
will a different gap on plugs reduce it? mine does it a fair bit and currently has 1.1mm gap ngk iridums (i believe thats the gap straight out of the box anyway)
ill probably get it adjusted to .8mm when i take my car in for some diagnostic dyno to solve my power cutting issue :)
Mines not popping on decel, only acceleration. I dont think its anything, just a bit rich i reckon. If it gets worse i'll start worrying but till then it can wait until i get a computer and a proper tune. Might gap my plugs for the hell of it in the meantime even tho it probably wont stop it.
Thanks for everyone's input btw
My R34 GT-T "pops" backfires mainly when cold if i accelerate hard then it happens as i decel. So i try to ease her in until she's warm. Doesn't happen when warm.
  • 2 months later...
Mine has been doing it when both cold and warm. The car is running stock boost btw.
I put in some Nulon Performance Engine Treatment E20 in the car yesterday and since I did i havent been able to get it to pop at all even when trying to force one out. Seems to have done the trick, and the car is idling smoother now too :teehee: Not bad for $13. So yeah, so far so good hopefully it stays that way. Maybe worth a try for you other guys?
*EDIT* Still does it sometimes, but nowhere near as much. Leaves less black on the tip of the exhaust than before though.
Edited by Scottydoo
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
