Hi guys, im in the process of re-installing my RB30DET, i have an OS Giken STR2CD Twin plate and am having trouble aligning the clutch plates.
The Gearbox is still in the car.
I have a Kingcrome clutch aligning tool, but this doesnt align the clutch plate teeth (for the input shaft spline) so i was thinking of sourcing an input shaft that has the same spline as the RB25 g/b.
Does anyone know what I can use? I was thinking Nissan Patrol might be the same since the clutches are interchangeable.
pretty much all the rwd nissans back to 180b use the same input shaft. I got a plastic one for about $10 at local repco. Not sure what you mean by the clutch aligning tool you have if it doesn't work?
  • 5 weeks later...
Ah my old thread. I ended up using an input shaft from the mechanic's workshop here at work. Apparently it was a Navara shaft...
It worked but dropping the motor down onto the gb with an OS twin plate was still no easy task. Only a fraction of a mm was enough for one plate to be out of alignment and It wouldnt go. Cranking the motor over at the balancer using a breaker bar with the clutch almost all of the way on helped. Dropping the rear gearbox mounts and using a jack on the bell housing to get the right angle is also critical.
I wouldnt do it like that if I had my time again... mating the gearbox to an already installed motor is alot less frustrating. Atleast in my experiences anyway.
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
