Some questions about the Endless brake callipers:
1. Is any one out there running them - if so do you have any comments?
2. Are any of the Endless range of brake pads any good?
More particularly I would like to ask for their "inch up" 343x32 rotor + 6 pot calliper does anyone know:
1. What pad size is it?
2. Can you get other than Endless pads - particularly the Ferodo DS2500 or equivalent?
3. How much piston area do the callipers have?
It is too bloody hard finding information on callipers most days. :rofl:
https://www.sau.com.au/forums/topic/196655-endless-brake-callipers-info-wanted/
im currently running endless disc and pads in my ap's. not sure what type they are but they are awsome and pull the car up really well but i have not used any other pad in my ap's so i have nothing to compare it too.
i saw an add. in my option 2 mag about the endless, i go dig it up and see if its got any information for you ;)
DJ...judt buy them. The prioce that kit is going for you cant lose. BD4s in Sydney use to run them on their GTRs, and whislt the cars never say that much track work in anger...they cannot be a bad thing based on the fact that most HKS demo cars run them
Yes they are good value for money. But my principal concern is getting some good pads to go with them. I finally found some Brembo rears & there was a set of Endless pads in them. They look for all the world to be nasty old school metallic type pads.
the 6 pot calliper looks to have a 152mm long pad. But that is just scaling the photo, so I don't know.
Just give Centrax Auto a call on 07 3349 7888, they are Endless brake distributor in Australia.
I run 6 pot 355 front 4 pot 330 rear. they are fantastic
Endless brake pads on one of the top pads, especially the race compound, the pads are superb.
Well I have heard good things, but.....I have two issues (OK, I have more issues htan the Readers Digest, but I digress).
1. The quoted friction coefficients are low - in the 0.35 - 0.4 range. Compared with the 0.5 I have on the DS2500's it looks horrible & low.
2. I need the pads to be useable on the road (ie work from cold & not squeel much) but also not run out of friction coefficient on the track when they get hot.
I sent an enquiry to Centrax, but they ignored it. Guess I will have to ring them aswell.
Have a look at their website,
www.endless-sport.com.au
it should tell you the range of pads they have.
higher friction coefficient doesn't mean better braking performance, consistence is the key. If a pad with high coefficient of 0.5 and performance drops off to 0.2/0.1 when it gets too hot, then what's the use of that pad.
Key point is to select the right compound for your application.
Richard, If they fit under 17's and you don't buy them, then let me know :P
The ones in the photo are just some random stuff from Yahoo auctions - they appear to be a 6 pot calliper on a 324 rotor. Not what I was after, but they would be a good thing none the less....so don't let me stop you.
Yes but according to the nice people from Ferodo the friction coefficient is stable across a large temperature range. That is one of the reasons why I like them.
I'm not saying Ferodos are not good :P they are probably as good as Pagid?
but I can tell you EBCs are shit.
I'm pretty sure you have to run Endless pads if you use Endless caliper system.
If you run AP racing, Alcon, Brembos, maybe Ferodo do the pads for them?
Edited by baboo
Yes they do. For all of them. Which is why I asked the question. I don't want to have to be locked into the Endless pad range because of the calliper.
Couldn't find out. The people who supply Endless pads pretty much only supply Endless pads. Whereas those that supply Ferodo stuff can't help much without a pad shape - which I can't find. There are a few sites with pad shape info on them, but matching to the calliper is too hard. I haven't yet run anyone down who admits to owning an Endless calliper.
There is info here, but I am stymied because my puta neither has a Japanese language install nor could I read it even if I had.
http://www.endless-sport.co.nz/Downloads/t...26/Default.aspx
Maybe try Tony Flood in Perth if you are keen. He is usually very knowledgeble/helpful.
Absolutely. Anything you can manage is all good. Have a look at the link from above because a couple of them have drawn the pad outlines of data sheets. May make it easier.
Also be curious to find out what the piston sizes on these things are....
Edited by djr81
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
