  • Replies 84
Congrats JET,
Can't wait to have a close look at it in person.
KEEP SAFE BUDDY!!
Seriously consider doing an advanced driving course.
We (SAU) should do one together, as a club day. It would be mad and we could learn a thing or two. My heart sinks when i hear of a skyline being involved in an accedent.
CONGRATS!!!
Can't wait to see it up close and personal.
KEEP SAFE BUDDY!
Seriously consider doing an advanced driving course. We (SAU) should do one together. Have a great day learning the limits of our babies (in jets case 1/4 of the limit will be more than enough :P) and learn a thing or two.
C ya soon!
Originally posted by JAGR33
Hey Mick, you do driving courses? or track days??
Sorry for being off topic...
I used to instruct advanced/defensive driver training courses and I used to do a hell of a lot of track days with different clubs etc.
Since I got my GTR I have done one track day at Winton too test set up and get myself used to the car. Getting a GTR fast is easy, getting it around really fast is not. My car needs new springs (on order in soon) and I need to retrain myself.
I have been speaking to a few guys I know who used to instruct with me or with other groups and we may get back into it soon.
Mick.
I have not done it but a few of the old crew like the John Bowe courses. Drive safe used to run a very nice course and I'll speak to a mate of mine regards Mircots now days. Used to be the best but they did loose a lot of really good personal. I think there is a real skyline freak there though now days which is always a bonus if someone is really interested in your cars.
If we ever get off our asses and start running courses again I will post it here. In the mean time do them all. With 400 rwkw no BS you need to really learn how to pedal it. That things is a serious tree hugger. You should be looking to build up and do motor sprot courses and get a Cams licence. The more time you put in on the track the better off you will be. If you get a track day that you can have passangers give me a yell. I'll meet you there and show you around.
Mick.
Calder Park.
Last friday of every month. You can do a few laps, just let the pass cars get about 3/4 of a lap in fron of you.
Problem is that you only get 3-4 laps, other slower cars are on the track and you catch up quick, real quick. But still fun.
Haven't been for a few months myself.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
