What do you guys think is going on with my bike engine? Basically it's a two cylinder engine and each cylinder has it's own carby.
Cylinder 1:
Cylinder 2:
And here is the underside of the head. Does this mean cylinder 2 is running lean?
Cylinder 1:
Cylinder 2:
These are my camshafts. Anyone care to comment?
These are my bores. You can still clearly see the hones marks but I measured the bores by eye and they are 89.5mm x 89.1mm at the top of the bore and 89.5mm x 89.4mm at the bottom. Ok I used a Vernier Caliper as I didn't have a bore scope thingy.
I was hoping to get away with new rings, bearings and gaskets. What do you all think? The pics there show that the piston skirts are wearing the bores.
I haven't got the bearings out yet so don't know their condition.
to me it looks like filings of some sort, possibly aluminium has broken and found its way in the oil & on the top of the piston?
in the oil are there any filings or chunks of anything ? cos if there are small filings of anything going through the cam while its spinning it can mark it like that or it could be a oil supply issue but the bits of metal on the top of that piston does not look good.
Sorry that's not the bit I was asking about. That's just crap from a bolt I had to grind off cos someone before me had completely rounded it.
What I'm curious about is the condition of those two different coloured valves and also the condition of the bores.
give it a fresh hone, fit new rings into bores without pistons and meaure the ring gap. do this in three spots (top, middle and bottom) and check to see if it is within spec. As for the valves i would check to see if they are sealing correctley (drop thinners down that port and see if it leaks past valves... bit dodge but it works) and then check the spark plug colors, if the second cyl has a light plug too it could be the mixtures... bikes are easy to tune what carbs are on it? check to make sure both needlles are on the same "clip" if they are and cyl 2 is still lean lift the needle up a clip on cylinder 2 and recheck plug.
i would get heads cleaned and checked anyway while they are off for safety sake myself.
Being a carb'd engine, I'm presuming it is the TRX850 or an earlier TDM900? Good fun machines both, in the right environment.
The wear on those cam journals is a bit of an issue I think. What condition are the mains and big ends in?
What sort of mileage and service schedule on the engine? And what was the reason for the pull-down? The different colour of exhaust valve deposits indicates a difference in mixtures (to my eyes anyway).
It might be worth checking to see if Yamaha plated the bores with Nicasil in those things too.
Well spotted. It's a TDM850. You know what's funny is that now that it has dried off a bit, the exhaust valves from each cylinder no longer look quite so different from each other. The erstwhile lighter one have no deposits on them though and the others do, it's just that those ones have lightened up a little.
Haven't got to the bottom end yet but that's what I think it's problem was. Rattley big end or main bearing.
How much fun is pulling stuff apart. Ha Ha
I hope you have marked every thing?
Make sure that you plasta gauge all bearing clearances when you put her together so that you don't build in the same problem. And measure your piston ring to piston gap with some feeler gauges just to make sure that you don't need to replace the pistons as well. I would just linish all your bearing running surfaces give her a hone and replace all your bearings, gaskets and either pistons or pistons and rings.
Check the cam chain tensioner cause they can make a hell of a noise when they are about to shit them self’s, if it is cheap i would replace it.
Get the carbies balanced and checked by a motorbike mechanic cause they can be a pain in the arse to get right on older well worn bikes.
Good luck,
Ryan
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
