Got a call from my local Holden Dealer today, my new SS came off a carrier this morning! Wasnt expecting it to arrive until well into January so its a early xmas prezzie!
Pick it up 5.30 tonight.
Will make a nice tow car! :rofl:
:):P
Edited by RNGTR
I spose you can put it on the back of a trailer... and go fishing on it?
Though I dunno why you didn't just by a 33...
Looks similar to a 4 door R33 doesn't it?
Im just joking! I couldn't help my self :P
Nice pickup mate, send it down to HPF and get a twin turbo setup on there and make some decent power :)
These things do sound tuff though!
Edited by abu
Yeah they do, I think i heard one in the carpark the other day... form the office!
If it was that, it sounded mean... but it could have been like a Ferrari or something knowing this place :)
But yeah, nice comfy, and roomy cruiser... Take it on a skid pad or two, see how she handles the waves :P
LOL thats awesome.
I like how you just slipped that in, very sly!
oh god. commonwhore
should of got an r8 at least. least they look half decent.
you like it so thats all that matters
good luck
The R8s are fkn awesome!
I'd love one of those in that new orange colour.
Edited by abu
If youre happy thats what matters. They do sound tough.
Dont forget, its a commodore ule! Go get oversized chromies, a subwooooofer, cut the stock springs to dump it, and hang your arm out the window while driving with your music blaring!
Cheers for all the good natured ribbing! :P
Yes yes... its Commodore its a V8 etc..... but its a pretty nice bit of kit. I struggled to find anything else BRAND NEW under 50k that was as good. The R8 is awesome but well out of my price range..... I need to budget for a new fun car too!
Im planning a Street Tuna 12sec package for it, a nice set of Tein Coilovers & tint. Thats it. It is a Daily after all.
Khoa, yep mate 6 speed manual.
Ash, this is the XR6T's replacement. Skidz NYE! The Evo's replacement is on the "to do" list for 2008..... most likely a Series 3 33GTR, if I can find a stock as a rock one. In Sonic Silver.
I'll snap better pix tomorrow, its raining here & I have to go out in it for dinner! Boo!
Edited by RNGTR
Cheers for all the good natured ribbing! :)
That will make it the one of the fastest fish out there! :P
looks good
do tell us how the petrol expenditure goes though (not trying to diss ya, but just curious)
strangely enough, i was thinking of getting the VT/VX shape hsv xu6 as a daily :P (was driving in my mums mazda 2 and my old accord/civic while my car was at the mechanics, and maaaaaaan u cant go back to a less powerful car)
[quote name='RNGTR' date='21 Dec 2007, 05:33 PM' post='3545774'
OMG, Tein made coilover for Holden!!!
12sec package? Its not hard to get those things to run 12 so i have heard. Series 3GTR, you might as well go for an R34 mate :banana:.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
