  • Replies 60
well. yes kind of. it depends how tight it is and how tolerant you are of the noise.
basically, if it is tight it will "skip" in tight turns at low speed, eg every time you park in the Woolies car park. Personally it didn't worry me because the on track performance was so good, but mothers with strollers used to look at me like I was the devil
sorry to hi-jack - but whats a good to average 1.5 diff cost these days?
Duncan - dont blame them :happy:
yeah under 20 or even slower. at quicker speeds the wheels can sort themselves out and turns dont tend to be as tight.
yes you can tighten a mechanical diff by adding or changing shim thickness. but aftermarket ones will already be pretty tight
Can you heel and toe?..
I know its quite hard to keep a 1.5 in cheak when you give it a hiding or in the wet and you dont heel and toe down gears.. compression lock up is a biatch..
Do u mean compression lock is a bitch on a 1.5way compared to a viscous diff or compared to a 2way?
If anyone wants a nice quiet streetable diff, go no further than a Nismo GT LSD Pro TT-Model 1.5way. It's the 'softer' model than the rest.
yeah i was looking into the Nismo GT LSD Pro TT-Model 1.5way, would anyone happen to know the life span of these diff before a rebuild is needed???
A lot longer than other diffs. 1) Because as they wear, you can adjust the preload to compensate and 2) they have a lower overall clamping force on the clutches than other diffs.
well looks like the diffs going in
thanks alot guys
cheers
if its a daily driver keep the viscous diff!!!
mine went from daily driver to weekend car as soon as the 1.5 way kaaz went in, but the nismo sounds nice
if i were you, i would take a ride in a car with a mech diff before you decide, its not the skipping thats the problem, its the *CLUNK CLUNK*, very loud!
and then you gotta try and convince everyone that its normal
??? Great back to square one???
thanks for the heads up champ
Any one else like to comment?
Just a couple of quick ones:
i also agree that you don't want a 1.5 way in a daily driver, particularly if you have any sort of subframe bush upgrades, pinapples or alloy collars. I'm sure people do it and are happy to do it but i think thats what pushed mine over the edge as far as being a nice car to drive around in.
Re the nismo wearing less and having adjustable preload. If it slips more (less preload) it wears the plates more. It's not infinitely adjustable either, there are 3 levels of preload so if it wears and you bump up the preload to the next step it's actually a bit of a jump, rather than a tweak. To tweak it you'd need to get it apart.
As an alternative, maybe consider a GTR rear end, they are a mechanical type lsd, 1 way and a bit looser than your average aftermarket diff so much nicer in the day to day grind, or even a torsen out of an s15. both options require a bit of work though and a few more bits swapped
They are a two way, not one way. I used to have a Nismo 1 way and it was very obnoxious. You do get used to it and you learn to drive around it a bit but everyone does look at you funny, which I quite enjoyed. Still, some days, maybe I was a bit tired or cranky, it would annoy me a lot. Now I have a full GTR rear end and it's much nicer on the street. The lock up on the track isn't as good but overall I would say that it's a better compromise for a street car.
To do this you need the diff centre, housing, half shafts, drive shafts and hubs from an R32 GTR. It all bolts up. I got the lot with rear subframe for $700 from a mate. SSS wanted $1200 so somewhere in between there is your window.
That said, I agree that you should get someone who has a 1.5 way or 1 way to take you for a little drive so you can see what it's like. Any old SAU type event should do or post up where you are and maybe someone from here lives nearby.
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
