  • Replies 50
If you don't score the turbo pump from blax240, I have a H3.3 I might be tempted to part with, as I have an H4 & a new hi flow I bought from SWR some time ago. Send me a PM coz I might have something else that would help your n/a that I'm not to fond of advertising on here.
Cheers, D
Is the hi flow you got from SWR a H4 ?,
if it's a H4 then I suppose it worth the $137 they want for them,
considering that to get one from the US would most likely cost about the same.
Nigel
No it's not that I know, but Stewart Wilkins claims it's every bit as good as the H 4 pump, but it's non genuine and it's NEW!
The blax240 pump sold for about US$74.00 = about AU$80.00 plus freight, about AU$30.00, but it's a secondhand pump.
And Dan, the cam I speak of is the speedo drive, isn't it a half shaft thickness offset idea? Cam?? as opposed to the spline in L20 & 28ET???
And my new motor is coming together nicely, will post if interested later. Still waiting on a few parts to come from US of A.
Cheers, D
My current L26 came with a mystery cam - couldn't find a receipt for it. I'm going to donate it to my friends 240k project. The L28 that I am building now has been set up with a Wade cam grind 733A - cam lift 320. There was buckets of valve clearance with the mystery cam, so I'm hoping not to run into any problems with the Wade number. Maybe I'll retest to be on the safe side.
I slept through the end of Blax240's auction and lost the oil pump, so PM's away to Ghostrider.
  • 5 weeks later...
The block is 280zx, with the dipstick holder pressed into the side of the block. The sump is L24 skyline, and the oil pick up is too. The skyline sump also has a dipstick holder, so I will retain that one, and remove the redundant 280zx dipstick holder from the block.
I won't be able to work on the car for 5 weeks though. My mate is away, and the car is in pieces at his house. Bummer.
sorry 2 bust in here but sort of on the same topic.
put a 260z C "nismo"? cam into my l24et, but the cam doesnt have any oil squirters. now the cam lobes r dry, this gonna cause a problem? thought all L6 cams had the oil squirters. if not how did they get oil up 2 them?
also idle vac is now at 10 In/hg use to b 15. runs fine etc but yea that normal?
cheers...
Edited by OUTATIME
I'm about to embark on this project too.
Does anyone know where I can get 36mm exhaust valves to suit the P90 head?
I have all the trick bits, so I'm expecting some real good HP numbers when this 2818cc L20ET is finished.
Cheers, D
  • 1 month later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
