I reckon McLaren and Ferrari will probably have the most work to do in winter testing if they are to be competitive from the outset in March. But then again, they are the best because they have the best teams.
  • Replies 3.9k
Posted Images
http://planetf1.com/story/0,18954,3213_4484551,00.html
ron looks like he's puttig the hard word on Vijay and trying to get one of his drivers into next years force india.
god... if they boot Fisichella out and get Paffett in there it truely will be the best F1 moment of the year.
I'm speechless.... GOD WHAT HAVE YOU DONE!!! IT IS SOOOO OUT OF PROPORTION!
THAT IS NOT AN F1 CAR, THAT IS A F*CKING TRAVESTY!!!!
Front wing 10% too big, rear wing 30% too small!!!!!!!!
without over dramatising it at all, i think i want to acctually cry
Good luck with all the typical first turn idiocy in 09 with wings that massive.
Also no more fuji 08 massa styled punting people off the road, which was always good for a laugh
Edited by ctjet
+1
it's not like the current cars are that good looking with the shark fin and OTT winglets.
if the racing is good then that's what matters.
if this doesn't work then Bernie should look into hosing tracks down randomly thru the race skidpan style to keep the racing interesting.
They will look different to that by melb next year, but +2 i almost want to cry..
Its probably just the body being tiny, but it looks as if the track has been decreased too!?
Its very 'A1 like' if you ask me. I really enjoyed how technically advanced 08 cars had become in the aerodynamics/downforce department. Why does it feel like some old dickhead and a bunch of never-were-race-driver people are making such drastic changes to f1.
They are going on about cost cutting.. Well how about the hundreds of millions spent on this years aero that is now getting scrapped!
It would have been much better to leave the cars as is, add full slicks and a boost button that gives another 1000rpm for 1 lap or something. That would make them probably 2sec a lap faster than current.
One of the major reasons overtaking and exciting racing has been rare lately is because they all use the same tyres. It was so much more mixed up and fun to watch when michelin was in there too
I want f1 to be the fastest that human engineering and technology can make it.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
