Hey guys, my cars sitting on about 99,600k's so the 100,000km service is goin to have to be done soon. Usually i service the car myself due to not trusting mechanics and not wantin to pay some-one to do soming i can do just fine (not take the car in for a service costing hundreds just for oil change, plugs and filters)
however the manual states that at the 100,000 mark things that need replaced are
oil
oil filter
drive belts
coolant
air filter (pod)
fuel filter
timing belt
break fluid
pwr steering fluid
diff gear oil
break pads etc
plugs
for me to do this would take quite some time and finding all those parts to suit the car might be trouble some i think, also some of those things id have no idea how to replace!
does neone know where i could get some-one to do all this? is it all covered by a mechanic if i ask for a major service? also if no mechanic would do all this where could i get all the parts that are direct replacements for the originals (dont want to go to supercheap and get cheap dud replacements)
i would prefer names of somewhere that would do all of these as works pretty busy atm.
any suggestions? where did YOU get your 100,000 service done????
thanks for all ur help
Irish
https://www.sau.com.au/forums/topic/199998-major-service-help/
oil
oil filter
drive belts
coolant
air filter (pod)
fuel filter
timing belt
break fluid
pwr steering fluid
diff gear oil
break pads etc
plugs
Irish
mate i can do all this stuff 4 u i can also machine your brake rotors as i have a brake lathe or u can just give me the rotors to machine up as i can do them on a weekend 4 u
dan and gav i had thought about. think i may give dan a bell as ive met him and he has helped me out a bit in the past.thing that im worried about is what ACTUALLY gets done to the car, i sorta want to bring it back to the condition it was in 50,000 ks ago, id like everything cleaned and/or replaced to sorta bring it back to the condition it was before it had been thrashed for the last year so i can up the boost in it and not wory bout something breaking or not being able to handle it. can such an old car with 15yr old componants take an increase in boost this late in the game without being rebuilt. id like the car to last a few more years!
ps thanks for the help again.
Making more power is almost always going to increase the amount of wear and the risk of things breaking. It's as much to do with how you drive it and how you look after it as how much boost you run or how much power you make though, up to a point of course lol
There are plenty of 33's getting around with 100k plus on them, and the vast majority have mods of some sort. I sold mine with 204,000km on the clock and the new owner has put another 30,000km on it since then, and it's still going strong. You should be fine as long as you don't go silly, but always remember that there are no guarantees with cars, particularly when modified!
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
