My speedo doesn't work and power steering turns off after 2 mins of driving.
Can someone tell me if my speedo cable is broken, I have taken these pics that might help:
EDIT::
I also had the problem that my car turned off, but cleaned the AFM so hopefully it doesn't confuse people about posts lol
https://www.sau.com.au/forums/topic/200239-is-my-speedo-cable-broken/
You have to forgive lingersoul - because to turbo Skylines with AFM's, whenever these symptoms pop up - it's rithual that we all say "it's the atmospheric BOV" as the problem is way too common.
OK, now back to your car - it sounds fairly serious... I'm guess the following:
1. Get your AFM (airflow meter) checked out - could be the filters are fileld with dirt and soil preventing functionality - get it cleaned out. Or, the metal connector parts are loose - open it up and get them resoldered (20 minute job).
2. Check all your piping, hoses and clamps for anything that's unattached or loose - replug them in tightly and fastened everything nicely and it should work again nicely.
3. Next time stop putting your car on Neutral all the time at the lights - assuming your's an automatic? Man, seriously - if it's auto, it's auto stop wanting to be manual etc... doing this all the time stuffs up the gearbox... but I would also check your battery's alternator - the thing that facilitates and holds the charge. It sounds as if the bettery isn't holding well. That's what I hate about hot days, your car runs like a dog.
Good luck mate.... try to the above and tell us how you go.
Why would he be shifting into neutral if he had an auto?
The reason your speedo isn't working and that your steering is heavy is because you have broken your speedo cable. It's a common problem with R32's. You can get a new one from Nissan for around $80. It's relativly easy to install and takes a couple of hours to do. I'm sure theres's a DIY guide on here somewhere.
I think the stalling issues your having is a seperate problem all together. The most likely culprit for an NA is going to be the air flow meter so i would check that first.
If it cheers you up, they're a piece of piss to fit. Unscrew it from the gearbox, pull the cable down. Push new cable up, screw in. 5 minute job.
where abouts on the gear box? is it near the pedals or the shift stick?
nah, at the end of the gearbox, on the drivers side, and on the side of the box.
edit: yeah, near where the shifter goes into the box.
Edited by QWK32
As mentioned, its a pretty simple job. Took us longer than 5 minutes as im not exactly mechanically minded but it is fair simple though. Just pull it out from the back and put the new one back in the same hole. Not rocket science and you would be silly to pay someone to do it :P
Must say a lot easier with two people on the case.
i just had one made up from my original cable. i sent it off to adelaide and they repaired it. cost me about $80 including postage. it arrived back in my mailbox 5 days after i posted it!
i will have to look up the name of the place for you.
in your case your odometer is also cracked at the back. the white plastic bit that sticks out the back. it might also have to be replaced. i guess this means a new cluster. but i would send the cluster and the cable to them and see what they can do.
fitting it is not that hard. all you need is a Phillips head and a 10mm spanner.
just so you know..... its that little yellow plastic piece you posted a pic of. You can clearly see its split. When it is split like that it will not grip the spindle therefore not spinning the gears in speedo cluster,, therefor no speedo. You could have bought a can of lectraclean or co contact cleaner and cleaned it from grease, $2 tube superglue and reglue it, then regrease it and then reinstall. Alot cheaper and no speedo cable replacement.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
