Around 7k
Knew someone would be a smart-ass!
Physio told me I have bicep tendonitis... spewing. So its a few weeks to a month of legs and squats.
Any upper body recommendations that are not going to make it worse while it recovers?
Get into a solid fapping routine. 3 sets of 100 reps per arm.
What do you guys think about home made weight plates ?
I am thinking of designing some in solidworks at work and then getting them lasercut to spec.
Ideas ? Interest ?
Also considering designing my own squat rack and cutting it here.
Sounds like you'll still be able to do pushing movements so triceps, chest, shoulders should all be fine to work.
Ideas ? Interest ?
If you can get them to be the correct weight (like within a gram of each other) then it should be fine.. but also consider that buying brand new rubber coated plates which have handles built in and are the correct diameter and cost about $3 a kilo or less delivered, you'd better be making a decent saving.
As for the rack, I can find you detailed plans of a power cage if you would like.
Any idea of root cause?
My knee tendonitis is actually a combination of hamstring tightness and glute tightness, and maybe the quads are involved too. Either way, if i stop stretching / rolling for any reasonable period of time even without weights I start getting knee problems.
The physio's gave me some excercises but they never helped, it took a long time to find the cause.
Yes Please !
the weight of the barbells would be pretty close, probably not to the gram though. however I know I could make them for a lot less than $3.00 per kilo.
are you looking at making barbells or plates?
as for plans..
http://startingstrength.com/files/starting_strength_rack.pdf
I'm sure that has all the info you need.
in the end it will look like this.
http://startingstrength.com/index.php/site/equipment
Wear em loud and proud eh?
Nah, I hate that carpet burnish feeling I get from scraping the bar up against my shin. I still get it a bit in trackies, but it's not as bad. Hopefully my shin skin will start getting thicker soon.
Are people doing deadlifts on leg day or back day?
I always seem to do them on back day purely because I like to squat on leg day and I wouldn't be able to get the most out of it if I did them on the same day. I do Bulgarian/straight leg deadlifts on leg day instead which seem to be ok even after squatting.
Edited by Mitcho_7
Are you guys more oriented toward the powerlifting side of training?
I just find I struggle to get decent weight up on deadlifts after doing 4x10 of squats. Doing them on my back day seems to work better for me I think. It allows me to give them my all rather than half assing them because I'm already spent.
I was just interested to hear other people's thoughts on how you work them both into your training...
Edited by Mitcho_7
Having watched some tutorial/classroom style videos from Mark Rippetoe over the last week, I'm convinced that deadlifts are primarily a back exercise (while they do hammer glutes and hammies something nasty though)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
