Around 7k
Knew someone would be a smart-ass!
Physio told me I have bicep tendonitis... spewing. So its a few weeks to a month of legs and squats.
Any upper body recommendations that are not going to make it worse while it recovers?
Get into a solid fapping routine. 3 sets of 100 reps per arm.
What do you guys think about home made weight plates ?
I am thinking of designing some in solidworks at work and then getting them lasercut to spec.
Ideas ? Interest ?
Also considering designing my own squat rack and cutting it here.
Sounds like you'll still be able to do pushing movements so triceps, chest, shoulders should all be fine to work.
Ideas ? Interest ?
If you can get them to be the correct weight (like within a gram of each other) then it should be fine.. but also consider that buying brand new rubber coated plates which have handles built in and are the correct diameter and cost about $3 a kilo or less delivered, you'd better be making a decent saving.
As for the rack, I can find you detailed plans of a power cage if you would like.
Any idea of root cause?
My knee tendonitis is actually a combination of hamstring tightness and glute tightness, and maybe the quads are involved too. Either way, if i stop stretching / rolling for any reasonable period of time even without weights I start getting knee problems.
The physio's gave me some excercises but they never helped, it took a long time to find the cause.
Yes Please !
the weight of the barbells would be pretty close, probably not to the gram though. however I know I could make them for a lot less than $3.00 per kilo.
are you looking at making barbells or plates?
as for plans..
http://startingstrength.com/files/starting_strength_rack.pdf
I'm sure that has all the info you need.
in the end it will look like this.
http://startingstrength.com/index.php/site/equipment
Wear em loud and proud eh?
Nah, I hate that carpet burnish feeling I get from scraping the bar up against my shin. I still get it a bit in trackies, but it's not as bad. Hopefully my shin skin will start getting thicker soon.
Are people doing deadlifts on leg day or back day?
I always seem to do them on back day purely because I like to squat on leg day and I wouldn't be able to get the most out of it if I did them on the same day. I do Bulgarian/straight leg deadlifts on leg day instead which seem to be ok even after squatting.
Edited by Mitcho_7
Are you guys more oriented toward the powerlifting side of training?
I just find I struggle to get decent weight up on deadlifts after doing 4x10 of squats. Doing them on my back day seems to work better for me I think. It allows me to give them my all rather than half assing them because I'm already spent.
I was just interested to hear other people's thoughts on how you work them both into your training...
Edited by Mitcho_7
Having watched some tutorial/classroom style videos from Mark Rippetoe over the last week, I'm convinced that deadlifts are primarily a back exercise (while they do hammer glutes and hammies something nasty though)
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
