no carbs after 7 is an older rule. not going to go into all the ins and outs or the pros and cons to it now as I dont have the time.
plenty of professionals follow the rule (maybe not power lifters) and I am talking fighters, wrestlers, actors prior to shoots, etc.
No carbs after 7pm? Gain muscle? Fcking lol. You really think your body knows what time you're eating???
Screw fasting... I love food.
Just train more
My opinion exactly, nothing wrong with eating after 7pm if you are trying to build muscle. Especially if you only just finished at the gym, you definently need to get food into you.
This information is for those overweight and are carb sensitive.
They should not eat processed carbs before bed
Those trying to gain muscle should be eating every 3 hours at least
Ant Tom, for the fatties, the body might not know what time it is (it does), but it does know if you need fuel for energy, and if it doesnt, it just stores the carbs for when it does............as fat.
So while some of the information posted is accurate, typicaly, not all of it is
As you mentioned though, this applies mostly for endomorphs trying to lose weight.
If you're a gym going guy trying to gain size, you're cheating yourself if you try to limit your carb intake to earlier on in the day.
Personally I don't get back from the gym until around 9.30-10pm on most days, so late at night is one of the most important times for my nutrition.
Can't beat a big glass of milk before bed.
So I take it you train people at your gym with powerlifting techniques to help them lose weight?
If so, that changes it up from the norm quite a bit as all everyone else does is high rep ranges and circuit type work.
Great question.
Here is what I do when I get new clients tell me they want to exercise to lose weight.
I get Max and the fattest client in the gym, Dave or Spiros etc
I explain they both train exactly the same, now do you think its the exercise or what they stick in their mouth?
Exercise burns around 500 calories an hour BUT if you walk or jog, once you stop your metabolic rate drops back to normal pretty much straight away, if youve been doing HEAVY resistance work it can stay elevated for hours, thus burning more calories
While all exercise is catabolic, heavy resistance training can promote an anabolic experience if provided with food straight after training, walking and jogging cant because you havent put enough load on your muscles.
Thats why squats are more effective than 10 isolation exercises done in the same workout, but the dumbest comment belongs to those that do exercises to "shape" a muscle. Idiots. You cant change your muscle insertions.
You listen to clowns saying preacher curls hits the lower bicep while concentration curls builds the peak. f**k I laugh when I hear that.
Someone please post up a pic of Arnold doing a double bicep. His right bicep is peaky while his left is long, I guess he trained each arm differently lol
I could go on for hours
For those interested I now write articles for Ironedge, read them here if you like
http://www.ironedge.com/blog/category/articles-by-author/markos/
I'm also doing similar. Dropping about 7kg over 3 or 4 months to drop in to the lower division to have direct competition as there are about 3 others with similar lifts and age and height etc.
Have you found your sessions difficult at all with the changes in your diet/drop of weight? Lifting around the same or less?
I'm doing compound lifts right now with a slight diet alteration to cut bodyfat (yes I want to get a bit more ripped for summer) <-- lol-worthy but true
It isn't lol worthy, do what makes you happy. I'll cut in a month or so for about 4 weeks, dgaf what people think tbh.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
