haha all good mate :P I ordered like 3:30 this arvo before I left work anyway, gotta get it done now before I run dry on WPI.
Thank god mate.. otherwise you would have just melted away or have to resort to eating chicken, beef, eggs and weird shit like that.. :D
Shut up :P I know it's just a supplement, but I hate having an eating routine thrown out of rhythm when something isn't available. Lately I've barely been making use of protein shakes and have been relying almost entirely on chicken breast mince (and now Kangaroo mince due to not being able to get chicken) for the bulk of my protein intake.
I just like to make things simple and easier to manage - WPI makes it so much easier.
HAHA!
I love how there are recommendations on servings on a lot of products. Take a scoop morning, lunch, tea......no, just eat.
someone should have told me about the 'stop 1 from your max reps' rule before, the other week i was doing bench and then I got to 7/10 and at the top of 7, i thought "hold on i'm tired maybe ill let it down slowly to rest and then i can push back up" = ended up with holding the bar above my chest, only able to push it up halfway and not high enough to set back on the racks...guy from the next rack came to help me.
hahaha, and you've just encountered pretty much the only use for a spotter ;)
well i was actually benching my lowest weight, but this was at the end of my workout so I kind of did AND didn't take that into account.
Bench doesn't quite work like squats haha. Once you're out of energy, you're finished.
I know that now.......hah....
tonight at the gym i had a bit of a funny moment.
had to do squats, but the squat rack wasnt free so I jumped on the smith. Anyway after the first set, I had real lower back pain. To cut a long story short, after the second and third set, no more pain.
Squats really does cure bad backs..... or maybe better form, not sure.
Just a theory that the experts can correct me on, but I would have thought the fixed bar position of the smith machine would cause all sorts of form issues because the bar should move around to suit your body's movement, not the other way around? Smith machine seems too linearly up and down...
That is correct
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
