haha all good mate :P I ordered like 3:30 this arvo before I left work anyway, gotta get it done now before I run dry on WPI.
Thank god mate.. otherwise you would have just melted away or have to resort to eating chicken, beef, eggs and weird shit like that.. :D
Shut up :P I know it's just a supplement, but I hate having an eating routine thrown out of rhythm when something isn't available. Lately I've barely been making use of protein shakes and have been relying almost entirely on chicken breast mince (and now Kangaroo mince due to not being able to get chicken) for the bulk of my protein intake.
I just like to make things simple and easier to manage - WPI makes it so much easier.
HAHA!
I love how there are recommendations on servings on a lot of products. Take a scoop morning, lunch, tea......no, just eat.
someone should have told me about the 'stop 1 from your max reps' rule before, the other week i was doing bench and then I got to 7/10 and at the top of 7, i thought "hold on i'm tired maybe ill let it down slowly to rest and then i can push back up" = ended up with holding the bar above my chest, only able to push it up halfway and not high enough to set back on the racks...guy from the next rack came to help me.
hahaha, and you've just encountered pretty much the only use for a spotter ;)
well i was actually benching my lowest weight, but this was at the end of my workout so I kind of did AND didn't take that into account.
Bench doesn't quite work like squats haha. Once you're out of energy, you're finished.
I know that now.......hah....
tonight at the gym i had a bit of a funny moment.
had to do squats, but the squat rack wasnt free so I jumped on the smith. Anyway after the first set, I had real lower back pain. To cut a long story short, after the second and third set, no more pain.
Squats really does cure bad backs..... or maybe better form, not sure.
Just a theory that the experts can correct me on, but I would have thought the fixed bar position of the smith machine would cause all sorts of form issues because the bar should move around to suit your body's movement, not the other way around? Smith machine seems too linearly up and down...
That is correct
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
