with the amount of cardio your doing if your not getting enough protein your going to be catabolic all the time... meaning all those resistance exercises are a waste because your not building any muscle... make sure your getting enough protein from whole foods and supps
your doing too many different exercises (as Birds has stated) simplify and look at making consistent progress in weight and reps
your doing a huge amount in the gym on a weekly basis... too much... I would ditch the cardio machines... they're a waste of time
ditch those scales, they're garbage
you do too much direct ab work and not enough posterior chain work... crunches don't give you abs, they just shorten your hip flexors and give you back pain
the basis of an athletic physique is a strong butt and back
girls typically can't handle as much upper body frequency or intensity as guys but they can handle as much if not more lower body volume
if I were you I'd squat twice a week at least... a heavy day, low reps and a light day, high reps... mixed in with the lunges and a few other lower body movements your already doing... a challenging high rep squat/lower body workout will burn more calories than any abcoreblaster class
if you want to circuit train, kettlebells, medicine balls, sprints and jumps are as good as it gets
I'd only deadlift once every week or even two weeks... it should be hard and heavy enough that your pretty much fried afterwards
you don't need to run on your off day... foam rolling, stretching and mobility work is better
just my 2c... train like an athlete, get stronger, faster and have more stamina... and as a bonus you might end up looking like one... seen some of the Olympic track and field girls!
Lol i'm sorry but I can't watch a Kai Greene vid after the whole grapefruit thing. The guy is an odd fella.
Wendlers 5/3/1 program looks alright, pretty common sense based, and it's something I might look at doing down the track. No way am I going from starting strength to that though lol... Same lifts for low reps would drive me insane of boredom.
There's quite a few different variations of the workouts.
I like to be in the gym as little as possible though so I enjoy it. ~3hrs a week and still gain.
Just got back from the gym, squatted 150 x 5 on my 5th set...been a while since the last time I pushed that weight but feels like I've got more in me.
strong Dezz!... nothing like the feeling of pushing heavy weight... I sleep better, have a better appetite and the effects it has on your libido is also nice hehe
they are simple carbs and if you look on the label it will tell you how much of those carbs are sugar
Cool thanks, knew about reading sugar amounts, was just wondering if the sugar carbs compared to the rest of the carbs was perhaps different. For example if sugar carbs are simple and the rest are complex.
Simple or complex what does it matter.
It matters because simple carbs are best to restore glycogen levels which I'm working on to prevent insomnia. This is why I'm wondering which kind of carbs are in protein shakes so that I know if I need to eat additional simple carbs to fulfill my requirements.
Weigh the whole chicken before you eat it, then put the remnants back on the scales and subtract from the original weight.
lol too late, already demolished half the chicken (thigh, wing, breast. Meat, fat and skin), along with 4 slices of tasty cheese.
My insides churn.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
