False!!!
sent from bathroom using one hand
So you're saying fapping doesn't have any adverse effects on test levels?
To my know knowledge studies have shown no fappin for a lengthy period of time elevates testosterone levels
" This current study examined the effect of a 3-week period of sexual abstinence on the neuroendocrine response to masturbation-induced orgasm. Hormonal and cardiovascular parameters were examined in ten healthy adult men during sexual arousal and masturbation-induced orgasm. Blood was drawn continuously and cardiovascular parameters were constantly monitored. This procedure was conducted for each participant twice, both before and after a 3-week period of sexual abstinence. Plasma was subsequently analysed for concentrations of adrenaline, noradrenaline, cortisol, prolactin, luteinizing hormone and testosterone concentrations. Orgasm increased blood pressure, heart rate, plasma catecholamines and prolactin. These effects were observed both before and after sexual abstinence. In contrast, although plasma testosterone was unaltered by orgasm, higher testosterone concentrations were observed following the period of abstinence. These data demonstrate that acute abstinence does not change the neuroendocrine response to orgasm but does produce elevated levels of testosterone in males. "
http://www.ncbi.nlm.nih.gov/pubmed/11760788?ordinalpos=16&itool=EntrezSystem2.PEntrez.Pubmed.Pubmed_ResultsPanel.Pubmed_RVDocSum
I don't agree at all.
Regardless of all the physical aspects of it, which i don't know about as i haven't researched it, you have the mental side.
And if doing it makes you feel better, and happier, and less grumpy....then i would say it's good for wellbeing
Fapping is not good for general well being anyway so its better to abstain from it all together
f**king lol.. what are you some sort of religious extremist?
Forget test and forget the fapping... dumping your load more frequently is better for your "health"
Wether you do it by hand/whore/pumpkin/vag/arse/mouth or tit is up to you.
Doesn't mean you should lock yourself up in a room with porn, tissues and cream to try and break some records.
There were guys on bodybuilding.com or whatever and they didn't fap for a month or so to see how it affected there gains, dont think it went to well.
I think it actually decreases your test if you dont 'go' for to long. Lifes to short to not fap for the sake of marginally higher test levels, cant tell me you'll actually notice a difference between a fapping bodybuilder and a non fapper.
lol
it may or may not be better for your own wellbeing... but I can guarantee its better for everyone else around you
food, sleep and sex... if I don't get enough I become a rage monster... Hulk smash!
many fighters abstain before fights... claiming it keeps them focused... I reckon it just makes them angry... which probably works too
When you don't fap/have sex often, the body has less of a need to produce sperm and testosterone, therefore lowering your overall levels.
Frequent ejaculation also decreases the risk of prostate cancer.
Studies have also shown a spike in test levels after sexual activity, and there is an increase in the strength of compound movements (such as squats) while on this test spike.
Jesus Christ man, do you even have a dick?
So it's no longer a question of who juices and doesn't...it's now "he must fap".
They must be talking about like 8 hours after...
Cause straight after is snooze time.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
