if bench is weak... do more bench.
also for every push movement, do 2 pull movements.
does not work for wanking
Thanks for that, Yer i hear that you should counter the pushing. Face pulls are a good one apparently
Bench is a little on low side compared to squat (assuming thats below parallel in a rack). Just hit it more often with lower reps and eat. Elbows shouldnt flare out, keep them tucked in.
Yer thats what i didnt check when doing it, was alone also. Will have to get someone to look at me when there next.
Elbows tucked in for bench? Ideally you want somewhere in between, tucking them in to far uses your tri's to much and is more a power lifting movement then one for building muscle.
I don't even care where my elbows are, unless I have an injury. Your body will have it's own form, different to everyone else's. Tucked in or not, whatever, none of that will stop you from getting strong in bench.
What do your sets and reps normally consist of for bench and how often a week do you do it?
Just stick to BB rows.
I find Pendlay Rows forces me to use good form.
Chins are also good.
Always start each rep by pulling the shoulder blades back first.
I generalised my comment too much. By tucked in I don't mean 90 degress to your body or close to your body, somewhere in between like you said, I use about 45 deg. herpa derp on my behalf.
Jealous at all you runners & squatters...
Smashed out my traps today, awesomeness. And going to work on those Bird's-fingers;
might take a while tho! Nap time now, then study :(
:cheers:
I can't do bench with a barbell anymore, hurts my shoulders for some reason, have to use dumbells instead, sucks having stronger shoulders then my chest, makes it hard to hit chest correctly :unsure:
how did you come to the conclusion that sore shoulder while benching with barbell = stronger shoulders?
The shoulder is a pretty complex joint/socket.
Lots of shit can go wrong with it and/or smaller muscles be left behind when other parts get stronger.
How strong are you with good form bent over barbell rows?
How is your shoulder mobility?
Pretty common issue with the bench/bro-press . I keep away from trying to bench heavy until my shoulders, back and triceps are ready for it.
As TTT said the shoulder mobility is a killer. If you have built the muscles for a strong shoulder girdle your bench will be stronger than without.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
