Has anyone had experience with the Hex Trap bar?
Looks like it could be a bit easier/safer on the back.
I'm not about to buy one, just a random discussion topic more than anything.
Part of me thinks that it'd allow you to lift more without risking the back, but at the same time makes me think that if the back is supposed to be getting a workout during DLs then you're kind of cheating.
I'm thinking it makes the squat a pull exercise rather than push too.
http://www.t-nation.com/free_online_article/most.../the_trap_bar_deadlift
Edited by ActionDan
Looks like it just targets your legs and traps more due to being able to load more weight onto the bar and retain a more upright/vertical spine.
You're right, somewhat defeating the purpose....though I'd definitely give it a shot myself right now - surely better than not doing deadlifts at all :P
Yes you will, I'm pretty sure your post count will start going backwards now too.
Until you go and squat again.
And don't hate on vagina's a decent one can take an absolute pounding.
Edited by ActionDan
I didn't squat last night when I was supposed to, will I lose all my gains?
If you don't mind contracting superaids and head cancer, you have nothing to worry about.
People keep referring to vaginas in a derogatory sense, implying weakness.
It's been said before, that testicles are pretty damn fragile, but the vagina can take a pounding by comparison.
Take that how you will :D
Edited by ActionDan
It's been said before, that testicles are pretty damn fragile, but we vagina can take a pounding by comparison.
Vaginas ftw.
Exactly. Doing this exercise to avoid an injury that never used to be there is defeating the purpose of building the back stronger.
Stronger back = deadlift more.
Working the rest of the muscle around the problem makes those muscles stronger, but not the injured ones = imbalances
Imbalances are right up my alley, I should definitely get one.
Just gettig freight quotes on racks at the moment.
What?
I'm saying deadlift the proper way after, in this case back, is healed.. Not do something that is a way around fixing the issue.
thoughts about tough mudder?
http://toughmudder.com.au/
was thinking about doing some training for it in september so bit of time to get 'fit'
Hit the uphill cardio with a weighted backpack and run through water.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
