The problem I currently have is that my mind is ALWAYS telling me to eat - even when my stomach says it's full.
So you have the fat person version of "I can't gain weight". Conversely, you need to feel that hungry feel. The more you feel it, the more you lose.
Hungry? Have a little lunch. Still hungry? Good, don't eat anymore for a couple hours.
The problem with most skinny people, who say they eat and don't gain weight, is that they eat when they are hungry. If you're trying to gain weight, you should never have that feeling. You should be constantly supplying food to stave off feelings of hunger. If you are hungry it means you failed.
So have lunch...you're full...an hour later you're not even hungry...but you eat more food just because you can. Load yourself with carbs.
This ^
I started out at 65kg and peaked around 93 or so after always saying "I can't put on weight".
In the end I ate 6 meals a day hungry or not, lots of carbs and protein, destroyed maccas etc, was worried about fat but because I was gyming all the time it wasn't an issue.
Was also the first time tried supplements and I was just using sustagen sport and plenty of it.
Now that's a turned into good eating habits where I eat 5-6 times a day, just not as large a meals and I maintain my weight ok (86kg).
I also think that a lot I younger skinny guys with fat metabolisms have better success in the mid 20s instead of early 20s as the metabolism slows down a touch.
My 2 cent from a formerly skinny guy :)
It drives you crazy when it's not just the usual "oh what's that stomach, you're hungry?" Deal. All I think about when I'm not busy is food lol
Try eating 13 slices of pizza, a garlic bread and large chicken parma :)
I was full for 5 hours but hungry afterwards hehe. Not to mention the amount of times I went to the toilet...
After eating super super clean for quite a long time, I had to enjoy myself with some real food
Easily. Last night was 1 cup rice with 300g kangaroo mince, then about an hour later an entire crust meatball pizza, then a touch over 1 cup of oats with a heap of prunes and dried apricots and a scoop of chocolate casein. Then I finally just fell asleep before I decided to try eating more.
Did you calorie count that Troy? lol
Hey guys does any 1 still have the old jac3d they are not using ! . I can not get anything out of this new stuff! tried stacking it with creatine . just not the same . even backed my bench press wait down and just pist off the kilos since this new shit came on the market! not fair they are still charging the same price ! :/
That sucks bro, are you gonna try sell your gym membership on gumtree now that you can't train?
Hey Mike Ye can still train mate but its Just slow going and tedious atm. Pushed up my hours. but fatigue is setting in quicker. Will Just push through it though.
After losing weight quick I've upped the amount of shit I've been eating again. Problem is I eat way cleaner than before so still losing weight :angry:
Still don't really mind losing that little bit of fat I had
Edited by UNR33L
losing weight is not an issue at all if its fat?
What the f**k is even the point to that ?
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
