Sounds stupid but stretch :/
I can now touch my toes easy when cold and palm the ground when warm because I stretch daily.
I also do back and hip stretches as well, has made a big diff for me.
Palm the ground with straight legs?!
I didn't think it was a big deal personally and not being able to do it was pretty poor in terms of flexibility.
Back when I was doing Karate it took me 10mths when I first started to get to my toes, I had THE worst flexibility.
I try and stretch regularly now as it pays dividends.
Stretching Poverty in my leg country is 3rd world for sure.
At your karate they weren't mean to you then. When I was doing budo yoseikan as a teen my teacher, Yoshiaki Unno ,pretty much fast tracked you to flexibillity via the pain method ha ha.. (he was a great guy tho).
Edited by rev210
I'll paste this here as I don't think anyone reads my build thread which is admittedly more a tracking tool for me, my stats and thoughts.
Well it was a mixed bag at the Fracture Clinic.
The good news is the metal work has not moved and the Dr is suggesting we wait another few months to give it a full year before making any calls.
The bad news is that he's also suggesting that removal might be the better long term solution because then there's no question of if it's causing me any irritation. That would mean up to 6wks off any impact sports/exercises etc, so no squatting and no DL. Everything else I could do and walking would be fine. I'm wondering if ham string and leg curls could be OK but I have no provision for doing those at home.
I'll be seeing the physio on Friday to talk about it more now that we know that at least the metal work is staying put.
Part of me wants it out never to have to worry about it again, part of me doesn't want 6 wks off when I'm just starting to get some momentum in things. Then I think well whats 6wks in the grand scheme of things if it means not having to think about the metal any more.
If I just go ahead and leave it in and then find out it's an issue say 5yrs down the track, it's a more serious surgery to remove it as the bone grows over/around it over that length of time. 1-3yrs is the ideal window for removal.
What would you do?
What would you do?
Better 6 weeks off NOW than 6 weeks off when you've made serious progress that you're really happy with. You'll have more to lose if you put it off, though the same could be argued that you'll get back into it much faster if you waited.
Personally, I'd do it now if it's causing irritation. If it wasn't causing irritation, I'd never* get it removed.
*as long as I continued training
EDIT: just read the last point again - remove it now.
I'm talking with the original surgeon also just to clarify a few things, as he's the local gun on these things.
I think I will get it removed, but I may wait to at least give it the full 12mths so everything around it is as strong as it can be when I go ahead and weaken the structure again.
Ad Troy: I'm happy with the progress I've made already, I started Squatting and DL 30kg remember... lol
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
