My novice comps are open to everyone, no Fed affiliation needed, no special clothing, no matter where you train. In fact, most lifters train elsewhere as my guys are mostly GPC members and no longer do Novice Comps
The GPC comps I hold require you to be a GPC member and wear a soft suit. They are sanctioned and National Records can be broken
ProRaw events are elite and a lifter must qualify during the year. If you guys are curious as to the standard
80kg MEN
730kg - James McNaught (GPC WA States)
675kg - Greg Frazer (ACT States)
672.5kg - Colin Webb (IPF Worlds)
650kg - Ben Bouchereau (GPC Nats)
640kg - Andrew Jovicevic - (PA Nats)
637.5kg - Amir Fazeli (HOTW)
620kg - Chris Stamatiou (CAPO States)
615kg - Ange Galati (GPA Worlds)
605kg - Emad Nayef (GPC Vic)
605kg - Julian Van Der Zanden
95kg MEN
800kg - Alex Lowe (NSW CAPO)
755kg - Matt Middleton (GPC Nats)
737.5kg - Ariel Dencio (GPC Nats)
732.5kg - Matt Brunoli (PR4)
730kg - Sebastion Oreb (CAPO QLD)
725kg - Joel MCaughn ( GPC WA States)
722.5kg - Scott Wasson (GPC Worlds)
715.5kg - Scott Hill (Oceania)
700kg - Max Markopoulos (GPC Nats)
695kg - Liam Belcher (SA open)
687.5kg Martin Nguyen ( GPC Nats)
110kg MEN
985kg - Dan Green (GPC Nats)
870kg- Ricky Goodyear (GPC Nats)
830kg - Nathan Jones (PR4)
825kg - Jackson Murrie(GPC Nats)
785kg - Richard Hozjan (Oceania)
775kg - Firas El Achkar (PR4)
770kg - Jeremy Buchanek (GPC Nats)
745kg - Nathan Wallace (GPC QLD)
727.5kg - Florian Loock (Oceania)
720kg - Alex Zerba (GPC QLD)
110kg+ MEN
1020kg - Odell Manuel (GPC Nats)
935kg - Wayne Howlett (GPA Worlds)
917.5kg - Dan Wright (ACT States)
910kg - Adrian Tullo (GPA Worlds)
875kg - Steve Tye (ACT States)
863.5kg - Stephen Pritchard (PA Nats)
822.5kg - Shaune Howlett (CAPO Tas)
810kg - Jack Pollard (GPC Nats)
800kg - Zach Turner (GPC Nats)
800kg - Luke Poli (GPC Nats
Leesh you look fantastic*, well done... you can see all the hard work has payed off... most girls that want to look like you have no idea what it takes
*but holy hell you have big hands... Birds your dick must look tiny
I'm a nude model Nick :P
Thanks Nick
Noone has said i have big hands before, I think it's the position my hands and camera when taking selfies that makes them look big, but thank you for making me feel self conscious about them
I have a 17yo boy training here. He joined PTC after we moved, so around 6 weeks ago. He had been training at Jets 24hr, so no squats or deadliest, just curls and benching.
Max has had him on the Beginners Workout, coming 3 x week.
Tonight we tested his 1RM's. He weighs 75kg and is 185cm.
Squats, he managed 105kg, goes quite deep
On the bench he got 75kg
He just deadlifted 150kg
Six weeks of training on the basics. Being a young novice lifter, we didnt push him like a seasoned competitor, but these numbers are okay for a schoolboy.
He seems to have been bitten by the Ironbug though, he normally trains with 2 other school friends, they went to a party tonight, he went to the gym first
Thanks Nick
Don't take it seriously, I just couldn't miss the opportunity to have a dig at Birds;)
Markos: that kid doesn't know how lucky he is... hope he keeps up with it
Exactly what it's title suggests...? One of the reasons I get the shit's when people bitch about this thread - it's a f**king discussion thread, we'll ramble however we wish.
Shut your filthy whore mouth.
Trozzle is such a power bottom
Thanks Nee-san I just spilt coffee all over my keyboard :rofl2:
Has anyone given Dorian Yates Blood and Guts Routine a crack? I have found I am a heck of a lot more sorer after it than the Jim Stoppani 12 week Challenge I was doing.
Edited by Kenna802
I had a mate reccomend me a program with 'swole' in the title the other day lol :rolleyes:
I do find it amusing how Bodybuilding.com have all these plans on their website (that naturally include an entire stack of 10 or so supplements for a beginner), yet they get ripped to shreds on their own forums!
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
