If I were eating a lot more, it'd be because I've committed myself more to the overall lifestyle. I definitely see and agree with what you're saying, it's just right now I'm not prepared to make the time to do it "right". For me right now, the "right" way is significantly less sustainable than paying a silly amount of money for the food. I'd go crazy after a week, my interest in even bothering to continue with any of this lifestyle would drop drastically, and ultimately I'd wind up with much worse results than taking this "shortcut"
I've done the whole meal preparation thing before - properly. It was good, but it took more time than I've got (or am willing) to spare right now. Was easy as hell given I was unemployed at the time lol...but ultimately I'm choosing a more enjoyable lifestyle routine over a more productive/efficient/dedicated (or whatever word you want to use) because I know in 2 months time I'll still be going strong with it rather than having burnt out in a week or two and hate myself.
Plus I currently have enough disposable income to afford it...before you say I could be spending that money on something more useful or saving it - that ain't happening either :P
As one of my good mates once said - "anything you're not prepared to sacrifice to achieve your goal, is something you desire more than your goal". There's nothing wrong with this, as long as I realise this is the case...and I do - I'd rather hold on to the little free time I actually have in order to enjoy my life in the short term.
"As one of my good mates once said - "anything you're not prepared to sacrifice to achieve your goal, is something you desire more than your goal". There's nothing wrong with this, as long as I realise this is the case..."
I say that to people complaining about not being able to lose weight. I usually add, so don't bitch about not losing weight if you want <insert thing they should be doing>.
Honestly, I could care less what people do or how they go about achieving the results they want.
Edited by ActionDan
Someone wanna find me a lab I can send a sample too? I might contact this mob to see how much / if they want to. Will get y'all to deposit in my PayPal :)
http://www.dairytech.com.au/images/stories/cka5884_dts.healthnutrition%20flyer_final.pdf
What on earth do you do day in, day out?
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
