If you don't count trivial sugars also, but at the end of the day it adds up to 200g sugar, did you not eat it?
Well in the context I was getting at with the word 'trivial', to hit more than 50g directly from things I consider to contain 'trivial' amounts, you'd be eating a ridiculous amount of food haha. At the end of the day I'm seeing these silly little amounts add up to maybe 50g of protein (and sugars are similar).
The amount of fruit I see some people consuming through the day blows my f**king mind though....I'd hate to think how much sugar they're taking in each day, even in the "healthy" form of fruit.
Just curious anyone on here who has seen results in benching , biceps and triceps for approx 6 months works in gains? Also I have read alot of conflicting views on carb and protein intake per day as well. I am currently 78 kilos and some body building sites say approx 260 grams of protein and 300 grams of carbs. Than other places I have seen tell me 120 grams of protein a day. Any ideas
about 1-1.5g per lb of bodyweight if you're counting. everyone's theories are different though. and so is everyones body. But now I'm just another statistic
Edited by jangles
I've seen results in benching, biceps and triceps in 8 months work in gains :D
Go to iifym.com and use the calculators to find your daily allowances for protein, carbs fibre and fat based on your age/weight/exercise level/what you're trying to achieve.
well its only around 170 if you choose the lower side. Its not much at all really.
average 250g chicken breast = 75-90g protein.
Hmmm that still equals approx 240 grams of protein a day. Damn that's a lot. I tried it last week while I was away training and just with powders I felt so full all the time I had to force it
Edited by jangles
When most these body building sites say to consume x amount of this and that is generally for someone who is all roided up.
I've started to eat to more salmon, swordfish and barramundi 3-4 times a week :)
Sweet potato is really addictive but I end up eating around 100g of carbs from it lol
I was taking in 300g+ and roughly 2500-3000cal per day at 78kg bodyweight and still dropped ~750g of fat per week. For me at least, there's nothing wrong with eating excessive amounts of protein. Worst case scenario is my body just shits it out without absorbing it lol. Winning.
That's about what I consume in sweet potato a day, about 1/4 of daily carbs
Better than a large bowl of pasta which can easily have 200+ grams of carbs based on a huge serving of it!
With excessive protein consumption, my urea levels were high after a blood test as well as liver function values, and that's mainly due to excessive protein that my body doesn't really need. Better to have more than less I say!
Exactly! Especially since something like a big fat steak is super filling and won't trigger cravings like an insulin spike apparently can. And it tastes gooooooooooooood.
That must be served in a mixing bowl.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
