definatley sounds like a mental thing Dan.
Maybe not getting enough rest in between either sets or workout days as well
Rest between sets is one thing I'd considered, is it better to take a longer break before that last set so you can do more continuous reps or take the same break, do less continuous reps then have to do more sets.
I dont think there is a magic answer there.
I have heard of people taking excess of 5 minutes rest between sets. I guess it really matters on when you think and feel ready to lift.
Markos could probably answer that better.
How am I supposed to send selfies to all da bishes in less than 5 minutes? That's crazy talk mang.
Markos what's your opinion on madcows 5x5?
What the f**k is a mad cow?
Bill Starr started 5 x 5. He chose that magic rep/set scheme because he designed the program for high school kids, he figured the P.E teachers were too dumb to remember anything more elaborate. He also designed it with incline press and not bench, but most schools didnt have one so he switched to flat bench.
Now that you know the origin, what do you think of it?
Jack sometimes takes 20 minutes between sets. It depends on the movement, the stage of the program and the weight used.
For a regular gym program 90 seconds is heaps
fish oil is win! 2 - 6 tablets a day helps with the inflamation of joints etc i find and so do a lot of people that use it....tho as you say not much conclusive testing apart from they "apparently" cause cancers etc
2-6 tablets? That's nice and definitive.
Yes Bill Starr, I'm running the modified version madcow 5x5 http://stronglifts.com/madcow/5x5_Program/Linear_5x5.htm
Edited by Dani Boi
So what do you think of it Dan?
The purpose of a program is to make you stronger. How long have you been doing it? How much stronger are you? Nothing else matters, nor does it matter what anyone thinks.
For a lifter that can go the distance, I use
1. Beginners program
2. 5 x 5
3. PPP
4. PTC Method
I've found the program really good so far. I was just asking because on the previous page you said that you prefer working sets for all reps as opposed to ramping weights that's all.
My numbers still fall into your beginner category but I switched to 5x5 because I wasn't making progress on Starting Strength anymore. So on 5x5, squat 105x5 - 130x5, DL 125x5-150x5, Bench 72.5x5-85x5 in 3 months. Probably not up to PTC standards but tbh I'm quite happy with what I've achieved so far. Just going to work up to 140/100/180 and see what I do from there.
It's interesting/weird.
using bench as an example, I've been going 93, 109, 116 for 8, 8, and then about 4 reps.
Tonight, I did a bit over 90 for 8 reps then moved straight onto 116.
Got 7 reps, on the first go, then failed out after 4 next set (3rd set) then did another 3 after that just to get th volume up.
So despite doing more in the second set (weight but less volume as I didn't make the 8) I managed the same 4 reps in that 3rd set :\
Dunno if that's good or bad?
Sounds about right. Jack's intensity and next set requirement makes sense for 20 min rest, depending on what he migh be doing.
Blood pressure on proper heavy lifts goes through the roof.
Regular gym goer is not stressing the body anywhere near that level for lifts.
Ate maccas today for the first time in ages, tasted so bad lol
Can someone explain to me the theory behind 5x5 training? is it just 5 sets of 5 reps for each exercise to basically gain strength? Or do you up it a certain amount every month or something?? Sure it's been covered but I don't come here much.
Edited by UNR33L
Why do gym regulars insist on coming up to you at the gym to talk about how they haven't been in for a week because they've had the flu / still feel crappy, then stand there for 20 minutes talking really close near you instead of doing exercise? Fu off you germ!
5 sets of 5 exercises. Increase the weight by 1.25-2.5kg increments every session on every lift.
Primary goal is getting stronger.
That is the lazy explanation.
Lazy is what depending on the program is.. I wouldnt say its any ingredient for great success.
Beginners program only
Edited by rev210
I meant lazy as in not going into all the ins and outs of the routine.
It can be difficult if you push yourself. I did it for a few months, I saw some strength gains but felt it wasn't pushing me enough.
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
