It'd quite a strict movement; one of the reasons it is done behind neck, because there is little variance in the range of motion. As long as you're taught and execute it correctly, this makes it one of the safer shoulder exercises. But no amount of safety in a range of motion will save you if not everything is sitting right when you do it.
Sorry birds thats not right at all . The range of motion and the position is bad compared to standard. It's got far more stress on the rotator cuff due to the position of the shoulder.
You can do them in relative safety, provided you are in correct shoulder position (and can get there with enough shoulder mobility).However, It will place much much more stress on the rotator, scapular and traps than front style. Maybe people don't like the regualr military press as much because sometimes the amount of weight they can do is less , relative to behind the neck (people like bragging rights). Add to this the 'standing' as opposed to sitting component and it's easier to get it wrong.
To help illustrate as to why these are strong on the rotator cuff , look at the elbow position. In the same way as the other pressing movement bench press. elbows out for gym punter bench press (ouch my rotators) vs the elbows in version for powerlifting.
Front press starts with the elbows in front and in. Moving the bar upwards vertically. Behind the neck is out to the sides and up out a little.
Either press needs a good strong shoulder girdle and upperback. Both assist slightly in actually building stronger supporting muscles as a compound movement. But, that aint enough.
My shoulders are pretty strong, I didn't need them.
Edited by rev210
liquid grip is great for gyms that don't allow chalk
f**k those gyms lol. Just don't let them see you start using it, and don't make a bloody mess....then if/when they notice you've got chalk, they won't usually care since you didn't get it everywhere haha
Either way, f**k those gyms :P
Also, fellow protein brahs...a testing company finally got back to me and are emailing me information on how to send them a sample. So the wheels are in motion
250x188xthe-visa-picture.jpg.pagespeed.i
Quoted for truth
I think it's more that some gyms (all of which would be commercial gyms) would get up you for leaving a mess lol...I know the chick at my gym was like "don't make too much mess or the cleaners might whine haha"...she cool though.
I just dont want to end up throwing up my food :)
You won't if you eat at least 2 hours before you work out for a large meal, or an hour for a small meal.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
