It'd quite a strict movement; one of the reasons it is done behind neck, because there is little variance in the range of motion. As long as you're taught and execute it correctly, this makes it one of the safer shoulder exercises. But no amount of safety in a range of motion will save you if not everything is sitting right when you do it.
Sorry birds thats not right at all . The range of motion and the position is bad compared to standard. It's got far more stress on the rotator cuff due to the position of the shoulder.
You can do them in relative safety, provided you are in correct shoulder position (and can get there with enough shoulder mobility).However, It will place much much more stress on the rotator, scapular and traps than front style. Maybe people don't like the regualr military press as much because sometimes the amount of weight they can do is less , relative to behind the neck (people like bragging rights). Add to this the 'standing' as opposed to sitting component and it's easier to get it wrong.
To help illustrate as to why these are strong on the rotator cuff , look at the elbow position. In the same way as the other pressing movement bench press. elbows out for gym punter bench press (ouch my rotators) vs the elbows in version for powerlifting.
Front press starts with the elbows in front and in. Moving the bar upwards vertically. Behind the neck is out to the sides and up out a little.
Either press needs a good strong shoulder girdle and upperback. Both assist slightly in actually building stronger supporting muscles as a compound movement. But, that aint enough.
My shoulders are pretty strong, I didn't need them.
Edited by rev210
liquid grip is great for gyms that don't allow chalk
f**k those gyms lol. Just don't let them see you start using it, and don't make a bloody mess....then if/when they notice you've got chalk, they won't usually care since you didn't get it everywhere haha
Either way, f**k those gyms :P
Also, fellow protein brahs...a testing company finally got back to me and are emailing me information on how to send them a sample. So the wheels are in motion
250x188xthe-visa-picture.jpg.pagespeed.i
Quoted for truth
I think it's more that some gyms (all of which would be commercial gyms) would get up you for leaving a mess lol...I know the chick at my gym was like "don't make too much mess or the cleaners might whine haha"...she cool though.
I just dont want to end up throwing up my food :)
You won't if you eat at least 2 hours before you work out for a large meal, or an hour for a small meal.
