lol I don't think people are that serious about it Leesh, I use the girls are stronger than me (among others) thing as a way of keeping ego very much in check.
I had a big chip on my shoulders back in the day and my life is substantially better without it :)
Hi Dan, how are things going?
Honestly I think it's ridiculous to care about what others think of you whilst at the gym. I stay focused on what I'm there for and give no f**ks about anyone else; every session I make progress so I'm doing something right.
Who friggin cares. You there to achieve your own goals or impress the chick next to you? Jesus Christ.
Whys so serious Leesh?
That's it, I had a laugh and went on about my workout
Meh, not great, hammy just will not simmer down. It's not painful but it's uncomfortable and if I use it it gets really unhappy, so I'm just doing upper body and trying to use it as little as possible.
Not much I can do about it right now so trying not to be too emo.
This.
ugh I'm just annoyed because someone backed into my car, my clutch died and I got defected. At least physio today, hopefully pain relief for the weekend!
Unrucky!
its the weekend so time to get drunk and partay!
I mean eat healthy and train at the gym
Unrucky!
Sorry to hear that, it seems you've tried everything and still not improving :(
You're just doing the opposite to me training wise at the moment,upper body and minimal legs. I wish I could do bench :(
Yeah unlucky alright, along with my injury and other personal issues I'm surprised I'm doing okay (kind of)
I just try to keep it in perspective.
I have a roof over my head, a decent job, loving partner, happy child, wicked dog, track car, friends, expendable income etc etc etc.
Some people don't even have running water. So it's hard to get too upset about not being able to voluntarily train up my muscles to be more pretty :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
