There's a pin-loaded seated leg press machine thingy I've used a couple of times, but unfortunately even on the max weight setting I still manage sets of 12+ reps lol
I like doing single-leg incline press with ~100kg loaded up after whatever my main leg exercise was (squats or proper leg press).
Fortunately for me, our leg presses use the old thin holed 25kg plates, which only fit on that and the smith machine. So our plates stay in the area or on the leg press itself...usually find 8 plates already on there thanks to a lazy individual.
not sure if it's been posted yet but:
http://www.news.com.au/lifestyle/health/remove-bar-from-windpipe-then-squat-guy-faints-in-gym-fail/story-fneuzle5-1226725940365
guy faints squatting 180kg (vid inside link)
Think we've all seen this before...
Honestly, any gym where guys are trying to squat probably 2x or more of their body weight on a front squat is going to have the potential for failure, nothing special about it being in Markos gym, other than if it was a commercial gym it would've been 120kg instead.
When I thought I'd badly done my back I fully dropped the bar on the safeties hard core, there was just no video.
Sometimes we will fail.
You know what else helps squats and deads?
I started a new thread on Marty and put up his NEW video after I started getting calls from news networks.
This is going to get bigger.
Funny how nobody wants to know about his 290kg deadlift but theyre all over a missed front squat lol
I'm surprised you're not getting told off for making your lifters do unsafe things like squats LOL
This..
Imagine that bloke from L33sh's Gym reaction if someone tried that at his gym lol He would of had a coronary
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
