Haven't ever really bothered for anything beyond the first exercise, really good stretch first then some light reps of whatever the first exercise is then by the time I'm done on that I'm usually already warmed up or things get warm from racking weights etc.
Work through the motion itself without weight first, it's not hard. If you can do it without weight you can probably do it with. If you can't do it without weight you likely can't do it with.
I actually find it harder to do the proper motion without weight haha....though it's leg day for me today, definitely going to give just squatting for a minute a go before I get into it.
ye old TTT said that in the past
If you can't do it without weight, your mobility sucks harder than a hoover.
Yes it's easier to stabilise the body with added weight that you can move around; circus acrobats use a bar on the tightropes. But you shouldn't have to depend on it to do the movement, else you probably have stability/form issues in the movement when using weight too.
Anyone watch Olympia? Heath won followed by Kai.
Felt sorry for Kai he looked shattered
Cutler made top 10 but not final 3, Wolf took third place
Edited by -FIGJAM-
Yeah I didn't pit Cuttler woth much of a chance.
Personally hoping Kai would take ot away but of of the top 3 I thought Wolf had the best bod of the lot.
No idea how the judges determine the winner of these events
No idea how much money the judges ask for from sponsors to determine the winner of these events
fyp brah
Squatting question as I've been thinking about what I may have been doing wrong previously to aggravate my back/leg.
In the lowest point of the motion, I notice my butt will tuck under a little which implies some rounding in the lower back, is that allowed/a problem/should be avoided etc?
Or should I only go as low as I can before my butt wants to roll/tuck under?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
