^Same
Also I'm meant to be cutting, not a competing strongman lol.
Currently eating Chilliz. Fail
Looks good to me
Rice and meat is all I ate in Asia...ended up losing weight lol
same, in conjuction with iifym
Havent been following my macros for a while now. I've slumped back into around 1400 calories a day, just not hungry atm.
Out of curiosity what is your weight Leesh?
Getting the wifey on a program and just trying to figure out a base calorie range for the day. Currently at 1,280 calories @ 63kg according to my fitness pal
57kg
After some suggestions if you please guys and gals.
So my little sister wants a program to do but at the moment she can only use machines, until someone shows her compounds.
(If she doesn't see a pt I'll show her when I see her in a month or so)
Should I put her on some kind of split or still try do a full body using the machines?
Once I've shown her the movements I'll probably get her to do Markos beginner program or something similar.
I usually consume 1900 calories a day and I would recommend iifym for that rather than my fitness pal
Wow you must either be very active or have a a high metabolism!
Good for when you need to cut hey :D
That is fairly normal for a female her weight/ size.
People that cut on less usually have a large cheat day or binge, not being consistent.
If you feel it's high in comparison to your intake, you really should be looking into what you can do to improve your maintenance.
I agree Birds - it's the fake natties that everyone hates, because they aren't truthful.
From what I've read, it seems quite pointless to start cycling until you're near your genetic potential as well - most of the people I know on test do not look that big / or are hugely strong. Biggest benefits seem to be the recovery ability and being able to eat whatever crap and not put on fat.
The other amusing part is that only a couple have a good understanding of what PCT is and how to go about it.
On an unrelated note, I started using chalk the other day, best training related decision I've made since going from a bro split to a proper beginner strength program.
Edited by bozodos
Chalk is a godsend for dead lifts. Everyone I've given it to has hated it at first and hated the feel until they added 20-30kg to their deadlift in an instant lol. I'm now supplying my gym with chalk cause they never fill the bowl :(
It's not that much food, but Birds volume training helps to keep her thin given I've banned her from most of her old cardio activities :P
Mate I would get her training mobility exercises, stretches, body resistance and supporting muscle exercises just so that she can get her body in good condition to start training the compounds properly when someone has a chance to show her.
Exactly; 1900 calories is actually under what I'm meant to be consuming. Iifym suggests 2100 calories a day for my size and activity level, but I've found a happy medium. The 130g of protein a day is more important to me :)
Yeah she's pretty cluey and is already doing basic body weight stuff, pullups, dips, pushups, etc. Knows a lot of stretches and mobility stuff from dancing.
Might just keep her doing that until she gets taught the compounds.
If she's a dancer she's probably got good flexibility and mobility all round, in which case yeah, you could get her doing some machine versions of compound exercises just to get her started - it's better than nothing or doing freeweights the wrong way. Machine bench, lat pulldown, seated rows, leg press etc.
Ahh it is more so that compared to the girls at my work they seem to be eating in the 1200-1500 calorie range. Maybe they just dont eat enough
If she's a dancer with good flexibility we need pics...
For science.
I can confirm for science
Ah brilliant I forgot about lat pull down :) thanks
For science.
Unfortunately for her she looks a bit like a female version of me, so you probably don't want pics hahaha
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
