^Same
Also I'm meant to be cutting, not a competing strongman lol.
Currently eating Chilliz. Fail
Looks good to me
Rice and meat is all I ate in Asia...ended up losing weight lol
same, in conjuction with iifym
Havent been following my macros for a while now. I've slumped back into around 1400 calories a day, just not hungry atm.
Out of curiosity what is your weight Leesh?
Getting the wifey on a program and just trying to figure out a base calorie range for the day. Currently at 1,280 calories @ 63kg according to my fitness pal
57kg
After some suggestions if you please guys and gals.
So my little sister wants a program to do but at the moment she can only use machines, until someone shows her compounds.
(If she doesn't see a pt I'll show her when I see her in a month or so)
Should I put her on some kind of split or still try do a full body using the machines?
Once I've shown her the movements I'll probably get her to do Markos beginner program or something similar.
I usually consume 1900 calories a day and I would recommend iifym for that rather than my fitness pal
Wow you must either be very active or have a a high metabolism!
Good for when you need to cut hey :D
That is fairly normal for a female her weight/ size.
People that cut on less usually have a large cheat day or binge, not being consistent.
If you feel it's high in comparison to your intake, you really should be looking into what you can do to improve your maintenance.
I agree Birds - it's the fake natties that everyone hates, because they aren't truthful.
From what I've read, it seems quite pointless to start cycling until you're near your genetic potential as well - most of the people I know on test do not look that big / or are hugely strong. Biggest benefits seem to be the recovery ability and being able to eat whatever crap and not put on fat.
The other amusing part is that only a couple have a good understanding of what PCT is and how to go about it.
On an unrelated note, I started using chalk the other day, best training related decision I've made since going from a bro split to a proper beginner strength program.
Edited by bozodos
Chalk is a godsend for dead lifts. Everyone I've given it to has hated it at first and hated the feel until they added 20-30kg to their deadlift in an instant lol. I'm now supplying my gym with chalk cause they never fill the bowl :(
It's not that much food, but Birds volume training helps to keep her thin given I've banned her from most of her old cardio activities :P
Mate I would get her training mobility exercises, stretches, body resistance and supporting muscle exercises just so that she can get her body in good condition to start training the compounds properly when someone has a chance to show her.
Exactly; 1900 calories is actually under what I'm meant to be consuming. Iifym suggests 2100 calories a day for my size and activity level, but I've found a happy medium. The 130g of protein a day is more important to me :)
Yeah she's pretty cluey and is already doing basic body weight stuff, pullups, dips, pushups, etc. Knows a lot of stretches and mobility stuff from dancing.
Might just keep her doing that until she gets taught the compounds.
If she's a dancer she's probably got good flexibility and mobility all round, in which case yeah, you could get her doing some machine versions of compound exercises just to get her started - it's better than nothing or doing freeweights the wrong way. Machine bench, lat pulldown, seated rows, leg press etc.
Ahh it is more so that compared to the girls at my work they seem to be eating in the 1200-1500 calorie range. Maybe they just dont eat enough
If she's a dancer with good flexibility we need pics...
For science.
I can confirm for science
Ah brilliant I forgot about lat pull down :) thanks
For science.
Unfortunately for her she looks a bit like a female version of me, so you probably don't want pics hahaha
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
