I believe there is a storage unit being auctioned off in Sydney tomorrow filled with ex-commercial gym gear/equipment.. Trying to get details, however my contact isn't being as forthcoming as he should! Lol.
So if anyone is interested, will post up details when I manage to get a hold of them.
  • Like 1
Pull ups and benching will usually suffice in the shoulder development department. If you're talking about "aesthetics", well, you're probably asking in the wrong forum..
If you are talking shoulder strength then pullups and bench arent going to cut it , unless you are wanting pretty ordinary abillity. Military/push press over bench any day. Balanced with external rotation movements to build strength through that motion. Thorasic spine and shoulder girdle strength are most peoples weak links.
Speaking as someone who used to do strict military press with more than 100kg for reps, including cleaning the weight (not off a rack)
Edited by rev210
agreed
You seem fairly knowledgeable in these areas rev, care to offer any insight on good ways to strengthen thoracic and shoulder girdle?
On another note, how do you guys stop your legs from bleeding doing deads? Long socks?
You don't have to drag the bar up your legs; you can pull the bar just in front of the shins etc.
Just give it time and practice...
Haven't had scraped shins for ages, but I used to get scabs when I was first starting out.
Socks / cup of cement, same thing :P
Haha doesn't bother me, but some people get worried if, god forbid, a drop of blood gets on the bar.
Curiously, if you can do normal deads how come you're doing Romanians?
Changed my training style a while back and these fit well into what I'm doing
I wear pants whenever I do deads, has helped but I still get bruising
mfw I have bigger calves than everyone in the gym apart from the 1 competetive bodybuilder and don't do any calf isolations at all.
regretting doing heavy db rows yesterday then heavy deadlift and volume squat today - lats and upper back did not want.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
    • Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
