I also feel the clean and press is one of the best exersices out there, strangely hardly anyone does them.
It's a bit technical for most. I like doing them they are a good brute strength movement. I try to slow the clean down as the press weight is usually light-ish for cleans. This way I get more out of the picking it up phase. Not doing them at the minute ,I am lacking some flexibillityt. Wrist injury needs sorting too.
2yrs ago in my build section I was doing 105kg for 5 reps (don't know what it translates to as 1rm). I forget what I was doing 12yrs ago but, I was significantly stronger back then. Could have been 120kg for 5.
I am keen to see what I can progress to this time round , now that I am commited to a gym for 12months.
On tip I can give for this is not faffing around with other pressing movements like bench while you are training this. Ideally if you are 5 or less reps then this would be the only thing you press in that week (no bench)
Edited by rev210
TM7GTR I started on ICF 5X5 3months ago after no gym for a few years. It's been a great program for relearning form and the weights are getting seriously heavy now. Plus the accessories added in give those mirror muscles a decent pump too. I'm seeing good results in my strength. Check it out
Getting back into it after a long time off and surgery? I would hit the mobility exercises and band work, for a few weeks (even longer if the surgery is a shoulder/back/knee joint) to get the body and joints loosened up / gain some flexibility for good range of motion in spite of potential scar tissue, and strengthen some of the supporting and core muscles before you get back into compounds.
Then when everything is feeling good and loose, start light on for everything, beginning with one exercise per session and slowly introducing more as you go so that you can rule out any injury or pain causers / narrow them down.
  • Like 1
Appreciate all the input guys.
Birds, the surgery wasn't joint or muscle related, and therefore won't affect my lifting at all so that's not to worry. It was just sinus surgery (septoplasty, turbinate reduction, etc.) so I was unable to lift for a few weeks due to limiting any head tilting/blood pressure rises, and how easily a nosebleed can reoccur.
Prior to that was a long travelling stint through Japan, so all up that meant around 2-3 months off.
Mobility is a must, and there have been some great suggestions to accompany that. I've had two basic sessions so far with light loads in some of the bigger movements to suss them out and how I bounce back currently.
I may just make a build thread as to not clog up this thread with endless discussion.
Cheers :happy:
Seems my shoulder still needs some time, I added a little bit of weight to some things on Friday and then did a little work on the car Sat/Sun and it pulled up a little tender =\
Where do I sign up for carbon fibre/titanium super composite power joints/tendons/muscles?
  • Like 1
No good, how bad are we talking?
Not sure, I've had some ultrasounds but still waiting on the docs assessment.
I've had 3 operated on before and it felt the same when it let go, big tearing then I hit the deck.
Oh well, looks like some time off and then get back into it slowly, again...
Stupid guts.
Inguinal hernia? Have to insert some gauze or whatever it's called and get more sutures yeah? That sucks.
Yeah, I've been there 3 times before, it sucks but recovery is quick.
  • Like 1
So has been confirmed. I have a small tear in my groin. Thankfully its not bad and doesn't require surgery.
Doctor has recommended 6 months off oztag and no stress to my legs. Walking is fine and jogging if i am up for it.
Also believes that my flexibility is disgraceful and i need to focus on stretching or go and do yoga
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
