Yeah that's not how it is
My ex girlfriend had zero libido and I used to take it personally but after we ended she still had those issues and I acknowledged it wasn't me
I guess because we all like to think we can turn on out partners easily so I guess in a way, philosophically, it technically could be our fault?
that's where my thinking starts to go. If I try everything that I can think of and can't get any sort of reaction there must be something wrong with me etc etc
I get yearly blood tests and I don't know about full panel, but my testosterone range always falls within normal...perhaps it could benefit from a minor boost...but there are other glands and hormones responsible for libido and they may be taxing me. I'm sure the hypothalamus in all it's regulatory glory would be impacting it somewhat. I seem to get libido in phases...can have a couple weeks of constant sex drive where I can't think of anything else, followed by very little interest in it for a couple weeks. It's weird. Prolly aligned to the moon phases lol
A lot of it has to do with tiredness and energy, I know this much. After a heavy gym session of high intensity or even with doms and fatigue the next day, the last thing I feel like doing sometimes is something energetic like having sex. Where this is a big problem is that your partner can take it personally and think it's a problem with them, lack of attraction etc. when it's a problem with you.
The...the feels are too strong
How long before you could do physical work again?
2 days off then light duties for a week, it was fine after about 3 days, lots of swelling for 2 days then it was gone.
Not painful though, just slight discomfort for a day or 2.
I tell you what though, its brilliant not worrying about pregnancy is a huge bonus, its like anytime anyplace anywhere now.
Good times.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
