I disagree if you're trying to lose weight, scales have their place.
This is true.
I say that because a lot of people just look at the numbers, which may go up if they're building muscle and it freaks them out.
If that's the case then a look in the mirror will confirm the direction they're headed in.
How did the visit to ptc go?
This is true.
Yes I agree with not looking at the scales when you're trying to build muscle only. I am proud of myself in this respect. I used to weigh myself multiple times a day. Since weight training I've slowly decreased this habit; I'm now looking at the scales around twice a week (which I hope I can stop doing soon)
PTC went alright, got some good tips and have now purchased a foam roller! However, still not confident in deadlift technique so not sure what else to do.
Edited by L33SH
Foam rollers are brilliant, you won't regret that. In what way are you not confident with the technique?
All you can do is keep practicing and seeking tuition when you're unsure.
Every persons body moves differently so there are going to be cues that are unique to your mechanics.
This ^
Not being confident straight away is normal . Remember the training (go over the tips and the session in your mind) and keep working at it. Confidence will follow as the things you have been taught bear fruit. It's good to repeat the training as soon as you can. Be ok with being a beginner.
it came out in the US months ago - I chose to wait for it at the cinema here rather than watch a crappy cam version.
weighed myself again, still at the same point as the last 3 weeks or so, given recent diet and training changes I'll check again in a few more weeks!
Thought i'd mention a bluray rip just came out yesterday :) I too was waiting for it in the cinemas but looks like they're too late for my business now.
Edited by UNR33L
I'm guessing Brotato is confusing her (the reporters) apparent sympathy and empathy with desire? Due to lip biting?
Or was it the package line he was referring too?
Edited by ActionDan
Leesh/Troy what was that diet app/program you were using, I just want to plug some numbers in and check some things.
It seems my diet needs some work.
Markos what are some staple meals and snacks your guys use?
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
